Thread: auto headlight switch AND daytime running light
    May 2012
    Denmark
    Default auto headlight switch AND daytime running light
    Well.
    Just had my EX rain/light sensor + auto light switch fitted. (07 estate)
    However...
    Living in Denmark, daytime running light (drl) is mandatory. Both the UEC and REC are set to daytime running light version 2.
    When the car stands with ignition on and the light switch is set to auto - the lights are on as they should be. However when I start the engine, the daytime lights switch off and the instrument panel lighting come on...
    So the functionality is "perfect" with ignition on/engine off - the light sensor registers darkness perfect, and changes the instrumental panel lighting accordingley - but as soon as the engine is started, it doesn't work...
    May 2012
    Denmark
    I guess left is just one thing... cheapest source for happy light show?
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    PM Kenp, if anyone knows he will.
    Aug 2012
    Vilnius
    hi, did you get any answer on this? I have the same "problem".
    May 2012
    Denmark
    Hi,
    I did get the Happy light show, however I have some issues with it discharging the car (not sure if it could be down to the fact that I turned it the wrong way round first time installing, and this potentially could have this effect)
    However haven't tried since...
    But through research, this is the THE only way of using auto headlight switch, light sensor "proper daytime lights, as required in DK" with OEM/standard lights... (I'm sure that through soldering etc this can be done in a different way, but if you don't want to do hardware modifications like that, then HLS is the way to go)
    Aug 2012
    Vilnius
    Thanks for quick reply. Then its a sad thing, not as AUTO as it should be.
  1. DAytime running light activation
    By jon1.9cdti in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2012, 22:38
  2. Retro fit Daytime Running Light Wiring
    By yorkshire jim in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2012, 23:23
  3. difference between daytime running lights and daytime styling lights ????/
    By montyfert in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2012, 13:09
  4. For Sale: auto headlight switch
    By husky in forum Parts for sale
    Last Post: 2nd April 2012, 18:26
  5. Auto headlight switch
    By G4GAV in forum Electrical & ICE (including SatNav)
    Last Post: 21st October 2010, 20:53
