Results 1 to 10 of 20
Thread: brake upgrade info?
    Jun 2006
    St. Helens,Merseyside
    Question brake upgrade info?
    Right ive done a bit of reading on this subject and cant make my mind up on 1 thing.but the list so far is
    full front end
    314mm discs
    calipers and carriers
    The rears ive worked out i will need the 292mm vented disc and wider calipers.
    But im stuck on if i would require new carriers aswell.
    anyone shed some light on this for me?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Yep new carriers mate
    Jun 2006
    cheers Paul, now i have the list complete well almost, forgot the splash/stone guards will be to small so would require these too lol.
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Some people just cut the lip off on the rear guards, as its a lot easier and quicker job in changing the whole lot.
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    Quote Originally Posted by Mike1.9CDTI View Post
    full front end
    314mm discs
    Ur inbox is full mate
    Jun 2006
    Quote Originally Posted by Sebastian View Post
    empty now mate
    Regular Member MattVecVXR's Avatar
    Mar 2012
    Torpoint, Cornwall
    Trim : VXR
    Engine : 2.8 V6 Turbo (280)
    Mileage : 82000
    What you'll need..
    Discs
    Calipers
    Carriers
    Pads
    7mm Allen Key
    T27 Torx Bit (for rear discs)
    Hacksaw (to cut back dust guards)
    Brake Hoses (optional)
    Brake Fluid
    Brake bleeder and bottle
    White spirit
    Copper Slip
    14mm and 10mm spanners
    Mole Grips (to remove handbrake cable)
    Plenty of rags
    I think that's about it.
    I cut a line from the outside of the guard following the profile of it and bent it back to increase the circumference so its just the right size for the bigger discs.
    Banned for Being a Numpty
    Jun 2012
    full front end
    314mm discs
    i wanted to do this can i just do the front for now or do the front and rear have to be done at same time?
    South east
    Quote Originally Posted by CDTiMatt View Post
    What you'll need..
    Discs
    Calipers
    Carriers
    Pads
    7mm Allen Key
    Brake Fluid
    White spirit
    Copper Slip
    Plenty of rags
    E20 Torx socket for the front caliper carriers and E18 for the rear ones, preferably ones that fit a 1/2" socket not 3/8", due to the torque you'll need to apply. Plus, for the front, a big breaker bar or pipe that goes over whatever you'll connect the Torx socket to.
    Quote Originally Posted by Rebellion View Post
    exactly as rebellion says i broke 3 3/8" adaptors tring to undo front carriers
  1. stage 2/3 info on next upgrade please
    By damo-SRI-T in forum Petrol Engine related
    Last Post: 18th December 2012, 22:32
  2. Big brake upgrade - Info needed
    By Gavin2.6 in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2010, 21:38
  3. Big brake upgrade!?
    By byebyeitsagsi in forum Handling & Braking
    Last Post: 10th May 2009, 20:56
  4. 314 Brake upgrage - Little info Plse
    By dv8 in forum Suspension, Wheels & Brakes
    Last Post: 20th August 2008, 15:40
