Thread: Vectra c boot not opening
    Aug 2010
    n ireland
    Default Vectra c boot not opening
    My 04 vectra c 2.2 dti boot will no longer open i have checked the fuses in the engine compartment as per manual this didn't help i have searched the site and not found a fix or how to for the vectra c my lock is keyless does anyone know what part i would need to fit myself to get this working again my mot up soon and they will need in the boot to check my spare wheel.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    If you got through the back theirs a little rubber grommet remove that. Then put a big flat blade screwdriver in the hole an turn that should manually undo your lock an allow you to test further/ replace the lock if needed
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Quote Originally Posted by shug176 View Post
    Its not part of the MOT any more fella.
    When you get it open, as per critch's instructions, it will more than likely just need a new micro switch for the button.
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    I had a similar problem a few years ago. I did fiddle with the micro-switch, which seemed to sort it out for a while, but eventually the problem returned. I went to the local Vx dealers where they told me how much it'd cost to replace the lock, which is what they diagnosed it as. As i didn't fancy getting a 2nd mortgage i took the plunge to get a brand new lock (approx £30) & fit it myself. Glad i did, solved the problem & saved some money too. I wouldn't suggest getting the lock from a breakers, you're likely to get the same problem again.
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    If you need one ive got one here you can have cheap just changed my tailgate so just sitting round in my shed
  1. siggy boot not opening
    By dahmich in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2013, 06:12
  2. Boot Lid Opening on Estate
    By Ben R in forum Bodywork & Interior
    Last Post: 9th August 2011, 19:26
  3. Boot lock not opening
    By Johnsdutton in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2011, 10:09
  4. Boot Opening
    By dc6839 in forum Bodywork & Interior
    Last Post: 26th January 2011, 20:46
  5. Saloon boot lid only opening with key fob?
    By spida_singh in forum Insignia car chat
    Last Post: 3rd June 2010, 01:04
vauxhall vectra boot lock problems
vauxhall vectra boot lock fuse
vectra c boot fuse
how to fix vauxhall vectra c boot catch
vectra c boot lock fuse
how to fix a keyless boot on vauxhall vectra c
https:www.vectra-c.comforumshowthread.php170999-Vectra-c-boot-not-opening
how to fix keyless boot vauxhall vectra
vectra c boot lock keyless
opel vectra c sedan manual opening trunk
how to fix boot not opening on vauxhall vectra
vectra c boot lock stuck
vauxhall vectra boot lid not opening
2007 vectra boot wont open
boot wont open vectra c
vauxhall vectra boot not opening
2002 vectra c boot not unlocking
my vectra c boot wont open
vectra c boot not opening fuse
