Results 1 to 10 of 14
Thread: No hot air?
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Default No hot air?
    I dont know whats going on with my car i fix one thing and something else goes wrong.
    I wasnt going to ask till i went out to check it but its bucketing it down right now so will ask anyway.
    I have no hot air the blowers work just blowing cold air no hot air coming out i was thinking a airlock or something the car temp is sitting between 85/90c what yous think.
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Check the heat flap valve is actually moving glove box will have to come out to check
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    matrix or wonder if its the thing that opens when you turn the switch from hot and cold? the one that opens to let hot water enter the matrix, or possibly the thermostat?
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Cheers Critch anything else ?
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    New thermo in it a month ago
    May 2012
    northumberland
    easy way id of thought mate if its possible, can you get to the water pipes that go to the matrix mark (i aint had need to look yet) and see if these pipes are getting hot?
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Where about are they.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Out side at the car now the 2 pipes coming from the stat to inside the car is hot so it must be the thing behind the glove box?
    Sent from my iPhone using Forum Runner
    May 2012
    northumberland
    both are hot? as one is the return pipe, if both are hot id say hot water is getting to the matrix???
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Yip the 2 of them are piping hot
