Thread: Uk to Continental light switch?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Default Uk to Continental light switch?
    Just a quick one guys, how do you switch the lights from uk to continental light pattern. cheers.
    Regular Member Ross DTi 2.2's Avatar
    Münster, NRW, Germany
    Remove bulb covers for dipped beam. there is a small metal lever inside the bulb recess, move the lever until you hear it click into place, job done. Its a bit fiddly to get at the levers btw. Its detailed in the manual.
    It doesn't actually change to continental pattern, it just flattens the beam, ie it doesn't point up and to the left any more. It was acceptable for my German roadworthiness test.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Worded my question a bit wrong. I actually ment the other way, From continental to uk. I take it its the same. Do you recon a continental light that has been switched will pass an mot over here?
    I'm not sure mate. I don't know if the MOT requires that your beam rises to the left or just stipulates that it must not rise to the right.
    If its the latter you might get away with it. Just remember that both headlamps must be the same as they measure the pattern from individual lamps and not the overall light spread.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Cheers for that mate.
    NP, hope it helps.
    Leicester
    Does not work on facelift cars though, unless you guys know something I don't!!! We could not find the lever on mine before I went to France.
    No Matt, pre-facelift only. Facelifts have to make do with stickers or new headlamps altogether.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by Matt View Post
    There is no lever on the facelift; unless you have AFL (maxifuse nr 37)
    Leicester
    Quote Originally Posted by Ross DTi 2.2 View Post
    Cheers Ross, I am glad I am not going nuts!!! A freind of mine has a facelift 2.0T and goes to Europe for 4 weeks each year, he has bought a set of LHD headlights and swaps them over each year!!!
    I'll just have the stickers!!!
  1. Interior Light - 4th light switch blank ?
    By Woody in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2012, 23:44
  2. Light Switch
    By calbert07 in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2010, 23:29
  3. light switch
    By sig63 in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2006, 22:02
  4. Fog Light Switch On
    By rob CDTI in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2006, 21:25
how to change a continental light switch
