Thread: Help with a Corsa please
    Nov 2010
    East Midlands
    Trim : design
    Default Help with a Corsa please
    Hi, Appreciate its not a Vectra (but I do have one as well) have a 2002 1.7Dti - with an annoying speedo problem - it will not work below 25mph - it kicks in at this speed and then works fine above that but as soon as it drops down to 25 it drops down to zero - mileometer does not record when the speedo is not working and the steering is in the lighter mode. Did have the 0500 fault code and replaced the Vehicle speed sensor and cleaned up the abs/speed ring on the driveshaft. Have also removed the pod and checked the connecting plug which seems to be ok - Have fitted a replacement CDR500 unit and read somewhere that the Speed Dependant Volume control could affect the speedo so will be trying it with the radio disconnected. Have looked on Corsa sites and there are loads of threads on speedo problems but can't find anything that helps - any suggestions would be appreciated
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Do they have a speed conversion box?
    Because do they take the speed from n/s drive shaft an then it's converted to display on dash.
    Only thinking out loud lol.
    Will look on tis for you later on
    Nov 2010
    East Midlands
    Trim : design
    Thanks for that -Not sure about a conversion box although there is a relay type thing in the fuse box - but yea they do take the speed from the Abs ring on the n/side driveshaft (even though the car doesn't have ABS)
    Nov 2010
    East Midlands
    Trim : design
    Thinking of changing the driveshaft cv joint now - with a new ABS / Speed ring on it although the old one looks ok now it's cleaned up
  1. corsa vxr
    By ecotommy in forum The 'Off Topic' room
    Last Post: 22nd February 2011, 19:26
  2. Anyone know anything about Corsa 1.2`s?
    By PeterVV in forum General Chat
    Last Post: 30th January 2009, 21:53
  3. Corsa C Alloy And Corsa D Grille
    By andy.l in forum Parts for sale
    Last Post: 6th May 2007, 12:46
  4. Corsa VXR
    By Madgunner in forum General Chat
    Last Post: 16th March 2007, 00:56
