Results 1 to 2 of 2
Thread: Knock from front end of my 2.0 DTi
    Regular Member Vectra_Power's Avatar
    York
    Unhappy Knock from front end of my 2.0 DTi
    Hi guys,
    I have a bit of a stange knocking type noise coming from the front of my 52 plate DTi. The noise is a single knock, similar to tapping the dashboard hard.
    It only happens when I'm slowing down in traffic and happens when I first apply the brake, even before the car has started to come to a halt (ie just brusing the pedal enough to turn on the brake lights). It sounds like it is coming from higher up than the suspension in the engine bay.
    I have looked under the bonnet and I can't see or feel anything loose, any ideas?
    Cheers,
    Chris
    Early vaecs had a problem with the springs seating in, it was fixed under warranty. Gave the same noise as you describe as I had mine done. Just needs a couple of plastic sleeves if it is that.
  1. front suspension knock
    By starykokot in forum Suspension, Wheels & Brakes
    Last Post: 2nd May 2011, 13:31
  2. Has annoy had there front shocks go noisey? or knock?
    By MCD in forum Suspension, Wheels & Brakes
    Last Post: 26th March 2011, 20:40
  3. near side front wheel knock
    By myelite150 in forum Suspension, Wheels & Brakes
    Last Post: 16th April 2010, 07:52
  4. Front suspension rattle/knock
    By damian s in forum Suspension, Wheels & Brakes
    Last Post: 24th January 2010, 16:47
  5. knock coming from front off side???
    By gizmo10119 in forum Suspension, Wheels & Brakes
    Last Post: 2nd August 2005, 08:01
