Results 1 to 10 of 15
Thread: Downsides and risks to remapping
    Regular Member Shogun's Avatar
    Aug 2011
    Default Downsides and risks to remapping
    What are the honest opinion downsides/risks to remapping the 1.9 cdti guys? Besides obviously the cost lol
    im a bit nervous about messing with an already 'delicate' engine according to most people on here,
    Admittidly I've had no problems in a years driving my signum though
    Also note that mines an auto
    Im up for anything that makes the bug gar drive smoother and not like a tank
    May 2006
    scotland
    My experience is that the 1.9 is not 'delicate'. I have been running a remap for almost 5 years without any additional issues. Sure my swirl rod is off and swirl pots 1, 2 and 4 are glued open but whether I had remapped or not would almost certainly have ended in the same result. The car goes like stink, does not burn oil or use water and returns over 50MPG. My remap is a BSR one which are noted for their high boost figures. My engine has handled this without incident for many 10s of thousands of miles now. Having said all that, there are no guarantees and yes there is extra strain on the engine.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    dpf could glog up quicker matey but an auto is megga fun with a map done loads they make me smile alol
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    i found the major downside after a remap was getting those extra lines on your face 'cos you are always smiling.get it done and get the dpf mapped out then removed.
    Regular Member 0114NIGEL0114's Avatar
    SHEFFIELD
    i wish i had the money to map my car now
    Trim : improving
    Year : 06
    give ben at mas a bell did mine £150 at work at same time as a work mates alfa
    SHEFFIELD
    sounds good but i cant upset our paul if i was to have it done id have to let paul do it for me mrk
    Aug 2011
    I heard Paul was Gunna do me a nice price after I get back if my holiday next weekend
    im convinced my engines knackered anyway though it's so damn loud!
    Regular Member shan's Avatar
    I ran my first soggy 1.9 150 on a caterman box for 3 year with no issues at all. Then ran my second one on a green dtuk box for nearly 2 year and no issues. Still got the green box if your interested.
    got to say they drive much better with a box or mapped.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Dpf will clog up or melt if not removed.
    Dmf will take more punishment.
    And the problems that I've personally had was an exhaust stud snapping due to increased heat, then a month later the turbo manifold cracked due to increased heat.
    Have now removed part of the undertray and cut out the top grill for more air flow
    Oh and I go through tyres a lot quicker!
    You also go through more fuel depending on your remap, (even driving with CC on at legal speeds)
    Another factor that you will have to consider is shorter oil change intervals due to increased soot content in the oil, I change mine every 5k (costs around £25 to do it yourself with a genuine filter, sump plug washer and genuine vauxhall 5w30 fs oil at trade prices)
    Some might say 5k is overkill, but it's a lot cheaper than fitting a new engine or rebuilding it
    May I also add that I am running a crd-t tuning box rather than a remap (it's not far off a generic remap) and it's on the setting that's *meant* to produce 215bhp, So a lower state of tune probably won't have the heat issues and shouldnt increase the spot content in the oil as quickly.
  1. what are the downsides of electrically disconnecting EGR valve on the 150 CDTi
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2012, 12:46
  2. GSi downsides ??
    By bembo449 in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 13:46
  3. Eds ipf...remapping
    By OPC in forum Diesel Engine related
    Last Post: 24th May 2010, 01:05
  4. Downsides of swapping my CDR2005 ??
    By AirCooledHeaven in forum Electrical & ICE (including SatNav)
    Last Post: 19th August 2008, 19:20
