Results 1 to 10 of 13
Thread: Engine stammer at 1800 revs cdti 150
    Regular Member goosey_1976's Avatar
    Nov 2009
    Dunston, Gateshead
    Vehicle : Insignia 2.0 SRi Nav
    Trim : SRI
    Engine : Diesel
    Year : 2010
    Mileage : 65k
    Default Engine stammer at 1800 revs cdti 150
    Hi guys, wondering if you can help me out. I've got a55 plate cdti 150 and it's seemed to have developed an annoying hesitation/ judder while driving. Say for instance I'm in third or fourth gear at around the 1700rpm area and I gently hit the gas I get a judder from the engine as if it's stalling. But it I hit the gas fairly hard the power delivery is nice and smooth. It appears to run fine when sitting still at this rev range but under load it does it intermittently during my journey. It's got 82k on and I've check the flaps and they seem to be ok. Any ideas would be appreciated
    Ta. Lee
    May 2006
    scotland
    It could be the boost from the turbo being temporarily interrupted. It could be a sticking EGR valve. If it were me, the first thing I would do is disconnect the battery for an hour to reset all the electronics and take it from there.
    Regular Member messermitch's Avatar
    Aug 2009
    Yorkshire
    Engine : 1.9Cdti 150
    Search the how 2's mate. There's a thread on hesitation at low revs. It's a simple fix, you just gotta take the boost sensor out and clean it.
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    For me it was egr
    Regular Member shinyb1's Avatar
    Jul 2011
    wigan
    it does this on mine when egr needs cleaning , clean your boost sensor while your at it .
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    3rd injector plug corroded, egr req cleaned or boost sensor dirty.
    Carnoustie
    is there any reason why it was allways be the 3rd injector plug? and could never be the other 3? just curios
    Ronnie
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by ronnie63 View Post
    Ronnie
    this is by far the most common fault with the 150 1.9 CDTi, everyone should make sue they have done this mod if they still have the yellow injector plugs even if they currently have no fault. I have know people pay out hundreds of £'s to fix the issue that the 3rd injector plug causes and still not get it fixed as the garage does not know what they are doing
    Regular Member GSiMrG's Avatar
    Mar 2012
    Harrogate
    What's the mod with 3rd inj plug?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    http://www.vectra-c.com/forum/showth...njector-wiring and it only applies to the 1.9 CDTi 150 before any one asks
  1. Screeching noise between 1800-2500 revs
    By Paul_O in forum Engine & Drivetrain
    Last Post: 21st May 2015, 21:31
  2. Engine splutters at low revs
    By Rb5scoob in forum Vectra C / Signum Troubleshooting
    Last Post: 1st September 2012, 10:30
  3. Engine only revs to 2800 rpm
    By BigTunz in forum Engine & Drivetrain
    Last Post: 28th September 2010, 18:38
  4. Mis-fire hesitation 1800 -2000 rpm cdti 150
    By Diesel Dude in forum Engine & Drivetrain
    Last Post: 29th July 2009, 09:45
  5. 1800 engine cover silver lightning
    By j1 wyx in forum Parts for sale
    Last Post: 1st March 2009, 14:38
