Thread: Z22SE Lumpy Idle
    Default Z22SE Lumpy Idle
    Hi guys,
    Have changed the CTS and lambda sensor.
    Car starts fine when the engine is cold. However, when the engine is at operating temperature if I switch it off and on again within 5-15 minutes, it struggles to start and fires up weakly.
    Any ideas?
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    This sounds like a similar problem I recently corrected with my mates astra 2.2, it was a stuck EGR valve, caused poor idle and running, struggled to start etc. I replaced it with a good second hand unit and blanked it off at the same time, its much better now.
    Good point! I had forgotten about the EGR. I think I'll get the cheater for it and blank it off.
    This bit confuses me though. Does the EGR have to working correctly before I remove it and blank it off? Or can I just remove a faulty EGR, fit the cheater and blank it off?
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Don't need the cheater, just black it... That's what I've done, still needs to stay connected.
    Norfolk
    Mileage : 69'000
    The cheater is not needed, I cut a blanking plate from a piece of alloy plate, bolted the egr off to the side so its still connected but not doing anything as such, the valve does need to be working correctly though or the problems will still be there.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    If the EGR is working properly they you can do without the cheater, but if the EGR isn't working properly then you need the cheater, although the car should run better but you may get an emissions light on the dash.
    To check the EGR unbolt it and pass 12v over pins A&E, this is my working EGR.
    Norfolk
    Mileage : 69'000
    With the symptoms the thread starter has described I'm guessing its not working correctly, my mates was working to some degree but not well enough, it would some times stick when tested in the manor of your video, the replacement was much better though and no lights on the dash.
    Vehicle : SRi
    Mileage : 137000
    The Cheater is only £10, and its a donation to a Forum so if the EGR is duff I'd just bang a Cheater on there rather than replace TBH, VX don't replace, they blank and Tech 2 it out.
    Thanks for all the info guys. Cheater and blanking plate purchased, can't wait for them to arrive. One less problem to worry about.
    Vehicle : SRi
    Mileage : 137000
    Don't forget to unbolt and give the tb a real good clean as the 2.2 has no icv, the butterfly controls the idle so and dirt build up affects a smooth idle. This won't be the cause of all your symptoms but it'll help it along.
    Sent from my Nexus 7 using Forum Runner
  1. 2.0t edition 100 lumpy idle
    By 6009tristanb in forum Engine & Drivetrain
    Last Post: 4th January 2012, 17:02
  2. lumpy idle on a 2.2(z22se)
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2009, 15:13
  3. Lumpy idle on 2.2 Direct SRi
    By Palmo in forum Engine & Drivetrain
    Last Post: 22nd January 2009, 18:53
  4. lumpy idle
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2008, 20:39
  5. 3.2 v6 Lumpy idle!?!
    By byebyeitsagsi in forum Engine & Drivetrain
    Last Post: 13th August 2008, 12:24
Z22SE IDLE SENSOR
z22se lumpy idle
egr stuck z22se
z22se idle
egr blanking plate for vectra c z 22 se
