Thread: Window fault code
    Sep 2009
    essex
    Default Window fault code
    Hi guys,
    I have a spanner light on briefly when I turn on ignition, the only present fault I can find on op com is
    B3974-05 drivers door select window lifter high voltage.
    Has anyone come across this before? Window works fine.
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Depending how long long it's on. If it is really briefly then it's normal
    If it's say 10 seconds am goes out then could be start of a glow plug failing
    South east
    A window fault code means the glow plug is faulty?
    Engine : 1.9 CDTi
    Get the codes cleared and see if it comes back.
    wirral
    36 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Quote Originally Posted by Rebellion View Post
    No spanner light on briefly means glow plugs
    Spanner light has jack all to do with anything other than engine faults.
    Sep 2009
    essex
    Sorry guys, I have just changed cars, have had it for 2 weeks, the car is a 52 plate Sri 150 2.2 petrol. It's only on for about 3 seconds, it's the only code I can't clear as its saying on the op com that the fault is present.
    Sep 2009
    essex
    Spanner light on for 3 seconds
  1. Fault Code help
    By MiniVauxhall in forum Engine & Drivetrain
    Last Post: 17th May 2012, 10:04
  2. fault code help
    By delboy2028 in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2011, 21:16
  3. HELP *Fault code* HELP
    By andymcniven in forum Vectra C / Signum Troubleshooting
    Last Post: 17th March 2009, 21:30
  4. Electric Window Fault
    By Big Sig in forum Electrical & ICE (including SatNav)
    Last Post: 19th August 2008, 13:30
  5. Electric window fault
    By daznsaz in forum Electrical & ICE (including SatNav)
    Last Post: 30th March 2008, 18:12
