Results 1 to 10 of 11
Thread: Poor fm signal
    Jun 2012
    Midlands
    Default Poor fm signal
    Hi all just wondered if anyone has a link to an fm booster for the cd navi 70 ? The signal sometimes fades and sound quality goes quiet.have read on tinterweb that you can buy signal boosters but would like a tried and tested one from you guys first please if possible,thanks,carl.
    Car is 2007 vectra cdti 150 with cd navi 70.
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Before spending money, I would suggest that you 1st remove the aerial and clean the brass thread as best you can, then refit with a dab of grease on (only) the rubber bit to help seal it and keep the weather out. There will also be an aerial connection below the aerial and above the headlining, but you will need to drop the headlining to check it.
    Removing and re-connecting electrical connections is usually worth a go to sort problems.
    Jun 2012
    Midlands
    Nice one mate i will have a go at aeriel then first and see if it improves,if not then try dropping headliner.i have read on the net of problems with the cd navi 70 tho.
    Jun 2012
    Midlands
    Just checked aeriel and is as clean as yor nans hat so dont think its down to that,any other folks had this issue and used a signal booster ?
    Regular Member Craig1985's Avatar
    harwich essex
    I'm having the very same problem with my cd70 all connections are fine tho
    Jun 2012
    Midlands
    Its a pain mate when listening to radio.may try a local ice shop see what they suggest.
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    If any consolation, I have cd70 navi and my fm reception is shocking, I tend to listen only to CDs cos it's so poor..
    Sent from my iPhone using Forum Runner
    Dec 2011
    Seaham
    My CD70 also has poor FM reception, although it might be where i live?
    Jun 2012
    Midlands
    Well ive just moved house and thought its cause im slightly in the sticks till i took a neighbours car to work to repair it,i work in a bodyshop,and that cars reception was bang on,then i used one of our courtesy cars from work and that was fine too.when i googled it someone had posted on an astra forum i think and had a link to a fm booster but was back in 2008 so the link had expired.there is one on radioshack on ebay but its for seat vw audi,its says vectra also but not too sure if it works so was after someone who has tried one.
    Sep 2013
    blackpool
    Vehicle : Vectra c
    Trim : Hatchback
    Engine : 1.8
    Hi everybody, My wife is also having problems with the cd30 fitted to her 57 plate Vectra it will change channel on it's own and our local station is just 1/4 of a mile from where we live, I changed the antenna for a secondhand one off ebay but it's still the same, how does the amplifier get it's power I know there is a blue wire coming from the base of the antenna but where is it fed from, also I bought an amplifier from ebay and yhe fittings where wrong, the listing was for a Vectra 2004>but the connecting parts are too big can anybody help
  1. where can i get an RPM signal?
    By Caveman_nige in forum Electrical & ICE (including SatNav)
    Last Post: 21st October 2011, 18:00
  2. Poor radio signal Vectra C
    By Haza1981 in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2011, 19:18
  3. Attention T-mobile Customers With Poor Signal;
    By ChrisBilly in forum General Chat
    Last Post: 15th October 2010, 04:17
  4. GPS signal
    By bigmac in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2010, 20:07
  5. No GPS signal For Sat Nav
    By steve74 in forum Electrical & ICE (including SatNav)
    Last Post: 28th July 2007, 22:08
