Thread: 1.9 CDTI 8v 1500 rpm MISFIRE
    Oct 2007
    Sussex
    Default 1.9 CDTI 8v 1500 rpm MISFIRE
    Hi all.
    I've just bought a vectra estate design 1.9 cdti 120, manual 2005 (55) 115,000 miles. Done a full service incl fuel filter and cambelt.
    Cleaned all of the egr valve, associated pipework and fully freed up a stuck solid egr solenoid - the pin wouldnt move..! But now good. I also cleaned out the MAP sensor which was coked up soild and cleaned up the boost valve on the bulkhead including the filters and plunger. Checked the vacuum hoses all ok.
    Now, after cleaning everything up i now have a misfire/jerkiness at almost exactly 1500ish rpm on light throttle loads, ie, you're in 2nd or 3rd gear coming up behing another car so you back off the throttle then put you foot down a tiny bit to maintain speed agaIn. When you do this the engine jerks/misfires as if it hiccups. If you apply more gas it seems to be ok and it only does it at around 1500ish rpm.
    Now i guess it may be egr related as it should now be working properly (it certainly wasn't before i cleaned it) and the map sensor can actually sense pressure variations.
    I read on here about software updates, looking on my car in the menu it says SW with lots of numbers etc then 2004. But no-one on here has said that any software updates have worked..?
    So has anyone suffered/suffering with this thats found a solution..?
    many thanks,
    Dave.
    Full Member
    Dec 2010
    London
    Engine : Z18XER
    Unplug the EGR and see how it goes.
    If it judders what colour is 3rd injector
    http://www.vectra-c.com/forum/showth...njector-wiring
    Also i hope you changed water pump as well. Its normally these that seize and take out belt.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Clean the boost sensor
    Oct 2007
    Sussex
    Water pump and tensioner / idler was done yeah, big fan of doing that at cambelt time..! Boost sensor (MAP) sensor was cleaned too. The injectors have the yellow plugs but i didnt think this was an 8v issue..?
    I'll unplug the egr to see if that helps.
    Not a software thing then..?
    Thanks for your replies
    Dave.
    Full Member
    Dec 2010
    London
    Engine : Z18XER
  1. CDTI jerking between 1500-2500rpm. Remedy ??
    By lesj in forum Engine & Drivetrain
    Last Post: 25th August 2012, 13:59
  2. Replies: 9
    Last Post: 5th August 2012, 11:02
  3. £1500 bill for CDTI
    By ONEMINUTESILENCE in forum Engine & Drivetrain
    Last Post: 24th July 2011, 12:04
  4. misfire on a 150 cdti- help pls
    By robk6112 in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2011, 11:21
  5. 1.9 cdti 120 difficult to start and low power under 1500 revs
    By johninthetoon in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2010, 07:46
