Results 1 to 10 of 26
Thread: Automatic Gearbox Oil - Change Or Not Change?
    Essex
    Default Automatic Gearbox Oil - Change Or Not Change?
    My automatic gearbox has done 97,000 miles and I don't believe the oil has been changed.
    The box is fine and there are no problems.
    I have heard that if there isn't a problem you shouldn't change the oil.
    If I was to change it I would get an Automatic Gearbox Specialist to change it as when I did it before it caused the box to get worse.
    The owners manual doesn't give any advice on when or if to change it.
    Thanks for any advice.
    Regular Member viper8's Avatar
    Mar 2011
    Northamptonshire
    i changed the auto box oil in my signum 2.8 turbo
    and it made no differance whotsoever
    have a little bit of whining in first gear .
    when i removed the oil it was very black and watery
    and it was supposed to be red ...
    after all the problems i had getting the filler plug undone
    i am glad i did it now
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Ment to be done at 50k
    Essex
    Thanks.Viper8 is there a dip stick on the box to check the oil? If there is whereabouts?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    If Af40 The dip stick is on the drain bung . There is a small grub screw under neath. Run upto temp, leave it running and remove it oil grub screw not the full bung. Oil will leak out refit screw when just dripping. Switch off engine and top up 0.5 oil.
    My 1st gear moans a little when car is hot and it has only done 37k
    Quote Originally Posted by rocket999 View Post
    I have heard that if there isn't a problem you shouldn't change the oil..
    My local Vx garage have told me the same thing time and time again. It's unlike them to turn down work when it's offered to them.
    My 2.2 direct auto is on 78,000 miles now and the autobox is still fine - touch wood.
    Quote Originally Posted by mattv6diesel View Post
    Source?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    If it's never been changed before (at 100k), don't change it! There have been reports of failed gearboxes shortly after an oil change.
    I drove my mate's Signum 2.2DTi when he first got it. The box was smooth as silk at 100k in fact it was smoother than our reconditioned one (20k) and he said he was going to change the oil just to be on the safe side...3 months later the gearbox failed, lost all drive.
    What I would do is regularly check the oil, burnt smell or a weird colour indicate problems...
    Mar 2011
    Northamptonshire
    Mar 2011
    Northamptonshire
    with mine i undone the little grub screw on the drain plug
    oil ran out .
    then i undone the big drain plug and it came out like crazy
    about 3.2 litres in total
    i put back in what i took out
    Mar 2011
    Northamptonshire
    with the filler plug ,that was a bigger problem ,i had Merikiito come over to help me
    Excellent guy !
    he cracked the plug open for me with some better tools
    drain plug on mine
    and the filler plug
    could not get to it because the turbo is in the way
  1. M32 gearbox oil change??
    By shb1988 in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2013, 20:51
  2. gearbox oil change?
    By will-crowe in forum Engine & Drivetrain
    Last Post: 15th December 2012, 00:04
  3. Does anyone know how to change F35 gearbox oil?
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 25th July 2010, 08:10
vectra zc automatic gearbox whirring in first gear
vectra c auto gearbox started whirring
