Thread: Adjusting tailgate stops... hatcback
    Chelmsford
    Default Adjusting tailgate stops... hatcback
    Hi chaps,
    Been starting stage 2 of my de-rattling project to try to make my car feel a little less old and knackered... Stage 1 was very successful and involved fitting the correct ARB bushes, replacing the shockers and also the upper control arms.
    Tried today to fix 2 rattles at the back of the car... One was simple (shove a piece of foam in a 40 piece socket set!) the other is being a bit of a pain...
    If I grab the boot spoiler (got an Irmy copy fitted) and wiggle it, the boot lid rattles up and down and makes a very annoying noise.
    I've tried to adjust the rubber stops protruding on either side from the boot lid, but nothing seems to work. Thought they were like the bonnet stops (the ones you unscrew to make longer and tighter) but they don't seem to do anything!
    What am I missing here? Are they supposed to unscrew to hold the hatch firmly to the body?
    Cheers guys...
    Right when you look at the bump stop you will see a big nut shaped piece near the bottom
    Also on the nut shaped piece is a mark like a little triangle
    On the base below the nut shaped bit will be 2 little marks like triangles , the mark on the nut shape bit will line up with one of the other marks
    What you need to do is rotate the nut shaped bit so it lines up with the other mark on the bottom using a.large adjustable spanner
    This then unlocks the buffer piece which you can then move in or out to what position you require
    NOTE IT DOESN'T UNSCREW YOU HAVE TO MOVE IT IN AND OUT MANUALLY .....BUT DON'T PULL IT ALL THE WAY OUT AS ITS A PAIN TO PUT IT ALL BACK TOGETHER
    (yes I meant to use capitals to make a point )
    Once you have it set correctly rotate the nut piece back to the original mark thus locking the buffer piece in place
    HTH
    Sent from my GT-I9300 using Forum Runner
    Chelmsford
    Mate you're a star!
    Was looking at that plastic "nut" and was wondering about turning it but didn't want it all to fall apart!
    Thanks so much, going to sort this now!
    No worries just don't do what I did and turn it too far and snap it
  1. Z30DT stops
    By Johnny-B in forum Y & Z30DT Specific
    Last Post: 9th August 2012, 15:14
  2. car just stops???
    By kiwiboy in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2011, 09:18
  3. Bump Stops - Help
    By Ian S100 in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2010, 20:15
  4. 1.8 low power, stops when hot
    By gassy in forum Engine & Drivetrain
    Last Post: 27th May 2007, 19:06
  5. bump stops.....
    By jamesy in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2007, 00:19
zafira b adjusting boot stops
zafira tailgate adjustment
https:www.vectra-c.comforumshowthread.php170875-Adjusting-tailgate-stops-hatcback
vectra c how to adjust boit stops
vectra boot lid buffer
vectra c rear hatch adjustment
vectra c boot adjustment
vectra 2005 tailgate adjustment
zafria boot stop
bumpstops vectra c rear
