Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Z19DTH Injector - bubbles
    Regular Member damers2000's Avatar
    Aug 2010
    Pontefract
    Default Z19DTH Injector - bubbles
    Decided to give the car a good clean today and also cleaned the engine bay.
    I noticed that while the engine was idling, there were very small bubbles coming from around one of the injectors where water had collected. All other injectors were fine where water had collected.
    The car runs fine, no issues at all but is this something to keep an eye on? Are the seals failing around the injector?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Injector seal on its way.
    But tbh if your doing one may aswel do the lot
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    See if its just the seal can you buy just the seals do you need to buy the full injector?
    Engine : 1.9 CDTi
    Just a new copper washer.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    As above mate only couple pence each for new washers
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    cool i dont know if mine is leeking but above one of them on the plastic cover there is black suet do you think my injector is leeking>
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Are they easy to fit??
    Aug 2010
    Pontefract
    chears for the advice, what symptoms do I need to watch out for when it gets worse?
    I've looked in haynes to see what kind of job it is and they suggest changing high pressure fuel lines etc.. is it necessary? They seem fine and look like new
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Will require the injector seat to be re-cut, I did one of mine a couple of days ago, also make sure you put the copper washer on the correct way
    Jan 2012
    Milton keynes
    Mileage : 38100
    Injector seat re-cut? What does that mean?
  1. vectra c 1.8 sxi small bubbles in header tank
    By vectra-man in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd January 2013, 14:55
  2. Emmisions Light, bubbles in expansion tank
    By nabber68 in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2010, 19:07
  3. Clio with bubbles in header tank???
    By luke4487 in forum General Chat
    Last Post: 6th February 2010, 15:04
  4. Bubbles on dash
    By JonSRi150 in forum Bodywork & Interior
    Last Post: 28th November 2009, 17:21
z19dth 3rd injector symptoms
injector seat reamer tool z19 dth
injector seat cutter milton keynes
