Thread: egr
    Aug 2012
    cumbria
    Default egr
    hi can anyone tell me where the e g r unit is on my signum 2.2 direct petrol engine and does it hav an exhaust gas pipe going into it and an electical supply help
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Its on the battery side of the engine mate, there's no pipe going to it as all the trunking is cast into the block. Its water cooled on your engine so if you take it off prepare to lose some coolant. :-)
    Sent from my Nexus 7 using Forum Runner
    Aug 2012
    cumbria
    thank you mr rush im wondering if its been removed i was reading about it and then use tech 12 to remap or summit along those lines the problem is the car will rev all the way when stationary but driving will not rev over 4000 then missfires if i knock the ignition off wait a few mins then its ok i ve even lost all power and had too pull over then wait and its ok
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    That sounds like a fuel pump/reg problem mate. I take it you can drive under low revs but when you put your foot down it goes into limp mode?
