Results 1 to 3 of 3
Thread: Oil Advice
    Essex
    Default Oil Advice
    If you have 5w30 oil in the vehicle and you wish to top up the oil as its slightly low is ok to use another grade or is it best stay with the same stuff. I'm not sure if its part synthetic or full synthetic that was used when I had it serviced, would this matter to?
    11 Post(s)
    Chances are, if they used 5w/30 then it'll be the fully synth long life stuff.
    IMHO, best to stick to the same grade / spec of oil for topping up.
    If you were top up using semi synth or 10w/40 then you'd most probably lose the long life properties of the existing oil.
    Essex
    Cheers. It didn't say on the recepit what oil they used just said 5w/30 might call them and ask if they used part or fully synthetic.
  1. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  2. Need help and advice please
    By Angel1368 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 11:19
  3. Need advice what would you do....
    By pipamish in forum General Motoring Chat
    Last Post: 2nd December 2011, 02:13
  4. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  5. Advice please?
    By RN37 VXL in forum Engine & Drivetrain
    Last Post: 16th October 2009, 17:59
