Results 1 to 10 of 17
Thread: coolant
    exeter
    Default coolant
    hi my 2.0 dti on a 53 plate has had secoundhand engine in . i have had it back for a week and it keeps needing to be top up with coolant . so far just over 1ltr . the garage said its because the engine and heater matrix had been drain and it might have air in it . my question is how much air could there be trap and how do i get it out quicker or what else could it be ?. the engine does'nt smoke and i can't smell oil in the coolant and the oil cap is clean. plus there is no sign of a leak .
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Surely if they were a half decent garage they'd have checked it didn't have an air lock.
    Get the garage to perform a pressure test
    exeter
    i did take it back and all i got was its trap air and it will be like that for a while . because its hard to get all the air out when the heater matix is drained .
    8 Post(s)
    There should be no air trapped in the system.
    That's why you have a header tank. It's for any air in the system to go to.
    Sounds like they're talking out their backside. System needs pressure testing and a sniff test carried out on the coolant for hydrocarbons.
    Essex
    I have just had a second hand engine put in and my water level is fine, no issues at all.
    wirral
    56 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    I agree it can be hard to bleed all the air out. But to say its ok is crap.
    Try turning your heater to full an fans off.
    Remove expansion bottle lid. An run car up to temp.
    Leave it like that for few mins an turn fans on full.
    This should remove any air from matrix
    exeter
    if the head gasket has gone would there be white smoke from the exhaust especally if it was drinking just over a 1ltr for 150 miles. because i have got no sign of it the engine does'nt smoke at all. i have smelt the water and it just smell like stale water . i have just unclip the left hand hose from the heater matix to make sure water was there and kept topping the expansion bottle up till i saw pink coolant coming out 4 ltrs . then recliped it and spent a hour trying to get the fan to kick in reving like it says in the haynes book . the temp went up to 94 but no fan the it kept dropping back down to 88-90 but no fan kick in ? and the coolant level drop . yet i can't see any leaks . i have run out of idea's going to see my local garage to see if they will do a pressure test . does anyone have any other idea's what it could be
    exeter
    there has got to be air . because when the engine is running in the expansion tank you get the little jet of coolant going back in and mine is not a consitant jet it keeps dropping like it stops . i justed tried your way critch . i'm hoping it has sorted it i will try again tommorrow to see if it has
    wirral
    56 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Try it again an try pumping bottom rad hose at same time.
    Can be a ball ache to bleed sometimes.
    You may have to take it for a drive to get the fan to kick hot air out. I had an Astra that a just couldn't get hot air to come out on interior. When was on the ramp. But took for short drive an was roasting hot. An worked perfect after that
    exeter
    Quote Originally Posted by Critch View Post
    i done it like this . this morning and with the expansion cap off the coolant level has gone up . it started off from level . is this right ?
  1. Coolant
    By tubby in forum Engine & Drivetrain
    Last Post: 16th November 2012, 21:36
  2. which coolant ??
    By VecPower in forum Engine & Drivetrain
    Last Post: 30th October 2010, 18:04
  3. Coolant Top Up
    By alembicbassman in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2010, 15:54
  4. Coolant
    By Bloicy 3.2 V6 GSI in forum Engine & Drivetrain
    Last Post: 23rd August 2009, 12:19
  5. Oil in Coolant!!!!!!!!!!!
    By mipai in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2009, 14:43
