Results 1 to 10 of 11
Thread: Vectra C Parkin Sensors not working
    Aug 2012
    Etelä-Suomi
    Default Vectra C Parkin Sensors not working
    Hi,
    I know, there are similar threads already but I haven't found the right answer - yet - so this why I posted a new one.
    So, I have Vectra STW 1,9 cdti -09 (150hp, autom.) with original front and read park pilots. Few months ago the rear park pilots started to live a life of their own and they made piip-sounds even when there was nothing to piip-about (this was when reversing). At this time the front park pilots worked ok.
    Now the whole system is down - front and rear. When switched to reverse the malfunction light turns on and there is this one bling-sound.
    OP-COM gives these fault codes:
    B1350 – Park Pilot Sensor Voltage Supply Low Voltage (02) – Not present
    B0954 – Park Pilot Sensor Front Left Outer Circuit Malfunction (01) – Present
    B0955 – Park Pilot Sensor Front Left Middle Circuit Malfunction (01) – Present
    B0956 – Park Pilot Sensor Front Right Middle Circuit Malfunction (01) – Present
    B0957 – Park Pilot Sensor Front Right Outer Circuit Malfunction (01) – Present
    B0961 – Park Pilot Sensor Rear Right Outer Circuit Malfunction (01) – Present
    B0960 – Park Pilot Sensor Rear Right Middle Circuit Malfunction (01) – Present
    B0959 – Park Pilot Sensor Rear Left Middle Circuit Malfunction (01) – Present
    B0958 – Park Pilot Sensor Rear Left Outer Circuit Malfunction (01) – Present
    The BIG question is what is wrong or broken? Where sould I start?
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    I'd start with checking power an ground to the module itself.
    And that the cables don't have high resistance.
    Because for all them sensor wires to have a problem seem to me their must be a common problem to them all
    Aug 2012
    Etelä-Suomi
    Hi Critch,
    where is this module located?
    wirral
    56 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Tbh on the vec I'm not sure it was on the rear right on a Zafira so I'd have a look their. Someone else maybe able to give you an exact location shortly
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    On the estate it's attached to the rear fusebox in the boot, I'd assume it's the same in the hatch.
    For every single sensor to be out like that it has to be either a module failure (or missing) or a plug come loose or something.
    Edit: the module is the one attached to the right hand side of the fusebox in this picture.
    Aug 2012
    Etelä-Suomi
    Hi Ian-Highlander,
    I have the same estate as in your picture. Few questions:
    - Is the module the black box with the ean-code on top?
    - Is there any way to test the box?
    - Do you know adress on a link to order a new one if it is broken? Price?
    Thank you very much!
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    The cheapest option is on ebay.. but it will have to be recoded to your car.. but it sounds like your parkpilot box have gone.. but as Ian says, check the plugs, and special the ground wire.
    But it could also just be your sensors that have gone...
    Aug 2012
    Etelä-Suomi
    Thanks kenp! I also thought first that it would be one the sensors that has gone, but op-com didn't point out one particular sensor. Correct me if I'm wrong but op-com should find out if one of the sensors is broken.
    I checked the wires of the box and for me the looked like new. And they were all firmly attached.
    Engine : 2.2 Direct
    I had one sensor failing.. but only showed when i had the towbar fitted... as that one then said it was to close.. when i replaced that not any problems afterwards.. ( i only har parksensors rear)..
    But op-com didnt say any errors on mine.. but yours are showing errors.. then its probaly the module..
    Aug 2012
    Etelä-Suomi
    Thanks again kenp. Are you sure that the box have to recoded? I checked on ebay and used boxes started from 45 euros. Maybe I'll get one of those.
  1. parking sensors not working
    By gsi-robster in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2012, 18:57
  2. sat nav or parkin sensors?
    By larrygroke in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2011, 14:39
  3. Parking Sensors stopped working
    By Snizzers in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2010, 18:52
  4. Parking Sensors stopped working, Please Help?
    Last Post: 1st September 2010, 14:12
  5. Parking Sensors stopped working
    Last Post: 30th May 2010, 09:43
opel b0961
opel b1350-02
vectra c parking sensor supply voltage
reverse light on vauxhall vectra c estate
opel b1350 02 klaida
Vauxhall DTC B0961-01
b 1350 02 parking
vauxhall b1350-02
opel b0961-01
code defaut opel b0958
saab b1350-02 park assistance
opel signum rear park pilot not working
opel zafira fault code b1350
parking assist switch not illuminating vauxhall zafira
opel vectra 2007 parking sensor not working
vectra c park pilot sounds
opel fault code b0961
vectra c parking sensors not working
