Results 1 to 10 of 11
Thread: HID Kit ? Error ?
    Oct 2011
    Glasgow
    Default HID Kit ? Error ?
    HI guys very quick question.
    I know that if you fit LED or HID kits into vectras the error lamp comes on because of can-bus, I recently got a HID kit for nothing out of a Ford Fiesta (long story) .. Theres a good chance once I fit this to my car the error bulb on the speedo will come on.
    Is there anyone that could recommend just error free bulbs or what I need to buy the full kit ?
    And to be honest if its just the bulb on the speedo thats on I might just live with it or will a message come up on the audio display also ?
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    What you might find is that the can bus detects a what it thinks is a blown bulb an stops power to that lamp.
    If you get some one with tech 2 to activate xenons in the UEC then that should stop an any bulb warming message an they should work fine
    VOTING UKIP IN AVELEY
    6 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    another option is to keep a sidelight bulb in the relay
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Ok, this is actually two different elements of the same thing here: LED lamps and HID kits.
    If you fit an HID kit you either need 'cancellers' fitted or many newer kits come 'CanBus compatible' that is with the cancellers built into the ballast units.
    For other lamps around the vehicle, if you replace with the LED equivalent you will notice them 'pulsing' when switched off due to the lamp check system passing a tiny current through each - a normal incandescent lamp reacts too slowly for anything to happen, but an LED will react to that voltage and briefly light up and then to randomly cause a lamp failure warning.
    With LEDs (even those marketed as 'CanBus compatible') you would need to add additional resistance at each lamp - as Soulman said one way is to keep a sidelight lamp in the circuit, others have cut the wire and added a resistor.
    (A 'quick question' .... on here.... you must be joking! )
    Oct 2011
    Glasgow
    Hahahaaa thanks for all the input, I'll see what i can do thanks
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved !!
    Irmscher Insignia CDTI 130
    Oct 2011
    Glasgow
    Right, I fitted the HID kit and the lights work fine with the ignition on but when you start the car the lights go out and the bulb error lamp on the dash comes on with the dip beam failure at the audio display. What would be the quick fix for this ? Just wanting to upgrade the lights for the up and coming winter.
    Quote Originally Posted by Handyandy-UK View Post
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Some HID kits dont like being on while you crank the ignition. Try starting the engine and then turning the lights on, I had to do this with my old set of HID bulbs.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    that would be my guess , even factory xenons don't like it .
    If my battery is slightly on the low side, one or both of my HIDs won't always spark up if I leave the lights on the auto setting.
  1. DAB box error
    By carlton in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2016, 08:55
  2. cd error
    By vicfzy in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2012, 14:55
  3. DAB box error
    By jimmywhu in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2011, 21:30
  4. Help!! Error CD?
    By MCD in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2009, 18:36
error canceller hid astra j
how to stop canbus errors and pulsing hid
hid kit showing bulb error
i have a vauxhall astra j and i have put some hids in they work when the ignition is on buy when i start the engine they go off
vectra c error free hid kit
2006 vauxhall vectra 1.9 cdti led hid kit
