Thread: Is my clutch going
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Default Is my clutch going
    Hello all a noise has started its mainly when i put it in gear and driving its like a rubbing grind but when i stop or put my foot on the clutch it goes away but the clutch isnt slipping and its going in and out of gear with no probs. What you think ?
    Regular Member murf2484's Avatar
    Apr 2006
    normanton west yorkshire
    Mark
    sounds like what i had going on with mine, took it in to local garage diagnosed as clutch release bearing however the nosie got worse and ended up with new clutch adn the dreaded dual mass fly wheel was on the limts of tollerance, so id prepare for the worse just incase £850 lighter i was.
    mines also a 1.9cdti 56 plate 65000 on the clock
    Craig
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Hi i dont think it is my clutch it has got a little louder i was just out in the car there and sure i heard a clunk noise when i let go the accelerator to change gear it sounds like its on the right hand side it doesn't do it when im in gear and no foot on the accelerator or clutch only does it when i accelerate.
    Any thoughts?
    Apr 2006
    Mark
    Dont no really what that could be ???? hopefully some one else may be able to shed some light on the noise, hope its note to bad
    Craig
    Regular Member 0114NIGEL0114's Avatar
    SHEFFIELD
    Thst sounds like clutch release bearing im sure of it
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I'm going to jack the full front end up tomorrow and get someone to rev it while in gear and i will have a look under the bonnet see if i can pinpoint where its coming from.
    My we brother thinks its the drive shaft or around there.
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    I'm having exactly the same problem it started with a tapping at idle and when pressing the clutch it disappeared now I have a tapping and knocking when going for second gear as the revs drop sounds like arb bushes have gone if you know how that sounds kind of thing
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    mine isnt tapping its making a rubbing noise as if the disk gard is rubbing the brake disk tbh it sounds more like a pipe is leeking and blowing air out i will try get it on my iphone while i take the kids to school if i open the window i cant really hear it only when the window is up.
    Edit: meant to say now and then it makes a we sound as if theres a dump valve but not as loud when i let the accelerator go to change gear.
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. 3.2 GSI Clutch
    By cmowen in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 13:31
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
