Thread: rear vents not working
    Regular Member felix_19's Avatar
    Aug 2012
    NORTHANTS
    Vehicle : vectra c facelift estate
    Trim : elite
    Engine : 1.9 cdti
    Default rear vents not working
    i'm new to the car but the rear vents don't seem to be blowing air. any ideas?
    cheers felix
    scottish region
    Is it a facelift if so good chance someones fitted them for show
    Aug 2012
    NORTHANTS
    Trim : elite
    Engine : 1.9 cdti
    what!!!!!!! thats poo!
    its the face lift model but if you have the fan on full you can feel the air coming through really weak
    scottish region
    Do u have it on full it has a scroller
    Aug 2012
    NORTHANTS
    Trim : elite
    Engine : 1.9 cdti
    i'll check tomorrow im sure i did
    milton keynes
    Try closing all the front vents. If its still bad you either have a pipe dislodged or the heater matrix is the problem. If it blows out fine , thats how its supposed to work. Are you sure you havent changed setting in the climate menu if you have an elite ( press the middle climate button)
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    i have this as standard on a facelift sri, if all vents are open the rear one will have slightly less air coming out of it, mine works fine on hot cold and aircon, im also sure in all vectras there is also vents under the drivers and passengers front seat that also blow air when the dial is set to footwell?
    Aug 2012
    NORTHANTS
    Trim : elite
    Engine : 1.9 cdti
    cheers for the help guys they were turned on in the settings
  1. Rear Vents
    By Davexctra in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2014, 16:51
  2. face lift chrome vents and rear vents
    By simon1 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2011, 21:13
  3. Rear air vents
    By si_hoss in forum Styling
    Last Post: 14th September 2010, 13:44
  4. rear vents
    By scottyd in forum Bodywork & Interior
    Last Post: 26th June 2009, 15:51
vectra c rear air vents not working
