Results 1 to 10 of 17
Thread: Ohhhhhh Nooooo (Help Please)
    Regular Member itsonlymedave's Avatar
    Aug 2012
    rotherham
    Question Ohhhhhh Nooooo (Help Please)
    After reading a thread about the pedal test i decided to go out and try it on mine,only to find it has 4 f'in Fault codes Grrrrrrrrrrrrrrr.
    Could anyone please tell me what these actually mean and how serious of a problem are they?
    Fault codes.
    P0036 (Heater control circuit,bank 1 sensor 2).
    P1565 (Speed control command switch out of range high).
    P1606 (ECM control relay o/p circuit malfunction)
    B2139 (Data mismatch,recived data does not match what was expected)
    Thanks.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    theres a sticky on here somewhere..or you could google them
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Google obd codes
    then on the sure search trouble codes gives you explanation and help on repairing fault
    Aug 2012
    rotherham
    Quote Originally Posted by nikroc View Post
    What i have put next to the codes are whats on the sticky,but wanting to know more about the faults and how seriouis they are but cant find anything to explain
    more about them.
    So hopefully some of the helpful members could maybe shead more light on the faults.
    wirral
    39 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Have you actually got an issues?
    Aug 2012
    rotherham
    Quote Originally Posted by Critch View Post
    Well tbh the car uses quite a lot more fuel than it should,and the big car with a spanner keeps lighting up and then going out again.
    That is one of the reasons i tried the pedal test.
    But didnt expect to find 4 fault codes lol.
    Is there anyway i can cancel all the fault codes off and see if tehy come up again?
    Aug 2012
    rotherham
    Google obd codes
    Tried but no joy lol
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    disconnect your battery for at least 15 minutes..but make sure you have your radio codes before you do.
    Aug 2012
    rotherham
    Will this cancel off all of the fault codes then mate.
    So if there still on when i try again after disconnecting battery then they are definatly faults that havent been fixed.
    Only asking as i have only owend the car for a few weeks.
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    indeed..it will wipe thecodes and as i said ..your radio code
  1. Aaaggghhhh!!!! Nooooo!!!!
    By Jay Kay 313 in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2007, 20:43
  2. Vectra NOOOOO!
    By Silver V in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2007, 20:47
