Results 1 to 3 of 3
Thread: sounds like Transmission knock
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default sounds like Transmission knock
    Not sure if anyone can help me but i think im developing a problem, my car is a Vectra 2.0 Turbo with 51300 on the clock.
    I think my DMF is starting to fail as i have a rattle on idle and you can hear it tapping away around the gearstick area and also disappears upon pressing the clutch pedal, now im finding it is a little bit worse but not to bad.
    What im getting now is from cold driving is fine as soon as it gets warmer i hear some knocking this is how it is hope it makes sense,
    Press clutch select 1st gear drive away
    At 2000rpm press clutch and go to select 2nd
    As the revs are dropping i hear a faint knocking around the gearstick area but more towards the front of the car in the footwells
    2nd, 3rd, 4th, 5th & 6th gears are fine and i dont hear it, im not getting and crunches from the box the gear changes are smooth and there is no knocking when accelerating or slowing down do you think this is DMF related i hope it is and not gearbox, i hope someone can help me.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    defo dmf whay ya descibing matey or possibly the thrust bearing
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Cheers Paul I was hoping it was that looking at getting it done soon
  1. Help Needed Please...Knock knock...
    By wishy1976 in forum Suspension, Wheels & Brakes
    Last Post: 23rd March 2012, 00:34
  2. Knock, Knock, Knocking...
    By Carmaduk in forum Suspension, Wheels & Brakes
    Last Post: 25th May 2011, 22:20
  3. Transmission Snatch
    By JDL in forum Engine & Drivetrain
    Last Post: 16th December 2010, 16:02
  4. Knock Knock whos' there
    By lizard in forum Suspension, Wheels & Brakes
    Last Post: 8th November 2009, 21:18
  5. Knock Knock Knockin on heavens door
    By lizard in forum Engine & Drivetrain
    Last Post: 17th January 2009, 00:10
