Thread: Can anyone help please.....
    Regular Member itsonlymedave's Avatar
    Aug 2012
    rotherham
    Default Can anyone help please.....
    While driving to work today all my dials shut down (ie) Speedo,Rev counter,Petrol gauge and Temp gauge.
    Was really confused as all the other electrics worked and the car still drove.
    Check fuse no 17 in the fuse box at the end of the dash inside the passenger door
    Sent from my GT-I9300 using Forum Runner
    Aug 2012
    rotherham
    Quote Originally Posted by marktaylor View Post
    Will give it a check in morning mate.
    But if fuse had gone then the dials wouldnt work at all would they?
    Mine just go into shut down and when i restart the car they come back to life.
    wirral
    58 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Remove the abs module plug an spray it with some contact cleaner
    milton keynes
    I would also look at the CIM connector , a member on here was having similar issues and I told them the way to clean the CIM connector and it has been fine ever since , as far as I am aware.
    Aug 2012
    rotherham
    Quote Originally Posted by Critch View Post
    Thanks for the advice mate,will do that aswell a checking no 17 fuse in the morning.
    Hopefully that will sort it out.
    Aug 2012
    rotherham
    Quote Originally Posted by kman247 View Post
    Thats behind the steering wheel isnt it?
    How would i clean that then mate?
    cleveland
    I cleaned abs connector and cim behind steering wheel and no diff at all. Is fuse 17 in the door or dash near the door? do we just take it out or clean or put new in etc?
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    All the "body" fuses are at the end of the dash panel.
    Fuses to check are
    F12 for overload protection fuse
    F17 BCM fuse
    But the advice given so far has been accurate.
    ABS connector - clean and ensure that the connector is secure
    CIM Conector - clean and secure.
    Check the earth tag on the CIM and steering collumn.
    And finally - check that the main battery terminals are clean and secure.
    Last of all - if only the dash is affected, then check for loose or dry solder joints on the 12 pin conector on the back of the instrument panel.
