Thread: Rear Parking Sensor Advice
    Leeds
    Default Rear Parking Sensor Advice
    Hi - wonder if someone can offer some advice, I've just fitted rear parking sensors and the kit has one of the dash mounted LED displays. The control until is fitted near the rear nearside light cluster. What is the best / easiest way to run the cable from there to somewhere on the dashboard?
    Thanks - J.
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    The dash mount mount should work wirelessly iirc and you just need to connect it to a + and a - at the front of the car mate.
    Is it a kit like this one mate?
    http://www.ebay.co.uk/itm/Wireless-R...item4cec7df501
    Nov 2010
    UK
    Engine : z18xe
    Year : 06
    Hi mate, i have the same wired one, i fed the cable down the back of the dash via the grille under the windscreen (theres a piece which pulls out.), you need to take the glove box out and try to get your hand in there. I then run mine under the rubber strip at the outside edge under the door.
    HTH.
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Which kit did you buy mate?
    Leeds
    Thanks all - it's an old Benross Parking Sensor kit (not wireless), bought it of a mate. Brand new, never used so thought I'd give it a go. Pretty easy to get installed just the dashmount part I left out. I'll have a good look at the rubber strips under the door to see if I can figure a route out for it.
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Lift up the door seal at the side panels then pull the side panels off to reveal the wire trunking then just run the cable from the rear of the car beside these wires then up through the glovebox to the display monitor/led display. Then re-fit side panels and door seals job done.
  1. rear parking sensor
    By woodze in forum General Motoring Chat
    Last Post: 29th May 2012, 20:53
  2. Rear parking sensor failure - advice
    By pgilc1 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2009, 19:40
  3. Rear parking sensor
    By ensign2006 in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2009, 08:54
  4. Rear parking sensor question
    By Ian T in forum Electrical & ICE (including SatNav)
    Last Post: 5th July 2008, 17:46
  5. Meta Rear Parking Sensor
    By 2.2direct-sri in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2008, 22:52
