Thread: An FYI for DPF's
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Default An FYI for DPF's
    At the beginning of the year my DPF was 75% saturated. I ran the DPF cleanout procedure on the diagnostic software and it dropped to about 70%. Never having owned a car with one before I thought that was probably normal.
    Roll on a to a a couple of weeks ago and the car is intermittently going into limp mode. After lots of checks I notice the DPF is at 84%. I ran the clearout programme and no change. In fact the DPF would complete the full 8 minute sequence.
    So the cars on stilts and I notice, by accident, that the flexi part of the exhaust has the very slightest leak, you can't notice it unless you really listen.
    So I order a new front section and replace it.
    Car still in limp mode, I start thinking about 300 bills to have it mapped out.
    Took the car on the M56 and ran it in 4th and 5th to Manchester and back. Everytime it went into limp I turned the engine off on and put my foot down.
    Eventually limp stopped. Hooked it up to the Diagnostics - 10%
    So anyone with DPF problems...try checking you haven't got a small leak in your exhaust causing the Regen not to run properly.
    Regular Member skip85's Avatar
    Wiltshire
    Vehicle : vectra c estate
    Engine : 1.9 cdti 150
    Mileage : 150000
    How can you check the percentage??
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    150 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Just get a forum mapper to sort it, blank the egr and gut the dpf job done better car no problems goes like stink and higher mpg
    Teapot Tuned 260/300
    https://www.vectra-c.com/forum/calendar.php
    Wiltshire
    Mileage : 150000
    Anyone in Wiltshire then??!!
    Regular Member welshhuw's Avatar
    Rhymney Valley, South Wales
    Sorry to butt in on the query; but I was wondering how do you know when/if you DPF needs a regen and how to go about it?
    The only info I have found is to give the car a good boot down the M4?!!
    Wiltshire
    Mileage : 150000
    Quote Originally Posted by welshhuw View Post
    Drop it to 4th, over 3000rpm and let it go for 20miles. you should feel a small jolt as the extra fuel goes in and alot of smoke.
    Wiltshire
    Mileage : 150000
    Quote Originally Posted by Barlow View Post
    Any one any idea on how to check %?
    Regular Member autech's Avatar
    Jun 2014
    Vehicle : vectra
    Trim : exclusiv
    Engine : cdti 150
    Year : 08
    Mileage : 90000
    You need TECH2, Vauxcom or OPCOM (outside of UK, of course) to check % I do believe good sir. May I also say that reading through one of the other forums I visit, it says prerequisits for running DPF regen are as follows:
    Car must be running at idle
    Car must be warmed up fully
    Procedure must only be carried out ONCE
    Nov 2009
    newcastle
    Hole in the exhaust was probably caused by the Dpf in 1st place being nearly saturated and causing excess pressure on 1st half of the exhaust.
  1. so dpf's ...... what do i need to know
    By big mick 1981 in forum Engine & Drivetrain
    Last Post: 31st January 2013, 21:47
  2. twin exhaust and dpf's
    By Grumpy1954 in forum Styling
    Last Post: 1st June 2011, 03:41
  3. DPF's EGR's and Tuning Boxes
    By R6Kev in forum Engine & Drivetrain
    Last Post: 27th August 2010, 19:29
  4. An interesting video for those of you with DPF's
    By John LE in forum Diesel Engine related
    Last Post: 21st July 2010, 09:03
