Results 1 to 10 of 18
Thread: Tyres with a VecC 3.2 Gsi Preface & 19" Snowflakes
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    130 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Default Tyres with a VecC 3.2 Gsi Preface & 19" Snowflakes
    Hi guys. As per the title. I'm looking for some 19" Snowflakes to upgrade my tired (no pun intended) and well kerbed existing wheels. Can anyone help with the answers to :-
    1 - What is the maximum tyre size recommended by Vx when this 19" wheel is used on a PreFace VecC 3.2 Gsi ?
    2 - What is the largest tyre you can actually use and fit both legally and sensibly on this 19" wheel with this car .... Or is actually answered in 1/ above ?
    Cheers and thanks
    Woody
    May 2012
    130 Post(s)
    Mileage : 131,000
    Ooops, should have added ... Correct tyre pressures too, front / rear ?
    Woody
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    As far as in aware,u can only use 235/35/19 or 225/45/19, best to stick with the stock size of 235/35 though, pressures should be 33psi all round, go easy on them, avoid pot holes like the plague and theyll remain crack fee :-)
    May 2012
    130 Post(s)
    Mileage : 131,000
    Thanks Ben, much appreciated, especially the info re potholes, yes I know this style is somewhat leaky after big road bumps.
    Woody
    Full Member RichM's Avatar
    Bracknell
    27 Post(s)
    I'm running 245/35/19 on mine with a 30mm drop and no problems. The circumference is a tiny bit larger than standard but not enough to worry about.
    Aug 2012
    http://www.idealdvdmall.com/
    Criminal Minds Season 7 DVD
    How I Met Your Mother Season 7 DVD
    May 2012
    130 Post(s)
    Mileage : 131,000
    Quote Originally Posted by RichM View Post
    Thanks for that, it does look like it will take a size (or 2) larger, I may just give it a go
    Tyre pressure wise, on my previous set of 18" wheels, Vx told me the recommended pressure is 39F and 35R (225/45/18's) so 33 would seem a little on the low side ?
    Woody
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    I also run 245/35/19 on my snowflakes, been told different things by different people regarding pressures but I run 33psi in every corner
    Vectra-C Extreme Poster Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    My snowflakes have 235-35-19 and tyre pressure is 40 all round standard rule i go off along with loads of people is double wheel size plus two so 19x2 = 38 + 2 = 40
    HTH
    And no cracks or loss of pressure and i live in stivks with bad country roads if there underinflated thats when the will crack and lose pressure
    May 2011
    HTH
  1. For Sale: 19" snowflakes with tyres
    By andy.l in forum Parts for sale
    Last Post: 15th December 2011, 16:49
  2. 18" Snowflakes with tyres
    By julian924s in forum Parts for sale
    Last Post: 8th March 2010, 21:59
  3. 19" snowflakes & tyres
    By rorycarz in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 28th December 2008, 14:00
