Results 1 to 10 of 13
Thread: where to get 19 cdti 150 timing belt kit?
    Carnoustie
    Default where to get 19 cdti 150 timing belt kit?
    just wondered if this would be a suitable kit?
    http://www.ebay.co.uk/itm/CADILLAC-B...item2ebcdd338a
    if not anyone point to a source
    thanks Ronnie
    Carnoustie
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Iirc the genuine vx kit including the water pump is about the same price as that on trade club (the first one you posted)
    Carnoustie
    Quote Originally Posted by John IS3 View Post
    Ok thanks will get a price today
    Nov 2010
    East Midlands
    Trim : design
    I would definitely get a genuine Vauxhall water pump - and which ever T/B kit you get make sure it has the bolts included - I've just bought a Contitech kit for a 1.7 DTi Corsa - opened the box and found there was only one bolt even though there is a guide pulley and the tensioner pulley - had to order a tensioner bolt from local dealers and been waiting nearly a fortnight now for it to arrive - and the bolts do need replacing. Also the Contitech (Continental) kits use the same pulleys as Vauxhall as we compared them at the dealers and they had exactly the same markings on the pulleys!
    Carnoustie
    Quote Originally Posted by alcutler View Post
    Ok thanks, dealers is coming in at £160
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    VX genuine kit and pump only. Ive fitted many of these and will only fit genuine - not worth the risk of nasty cheap pumps etc..
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by AntSSSS View Post
    Sound advice - but not sure about the belt and pulleys - I spoke to a technician at Continental (who make the Contitech belts and kits) the other day and he told me that they supply the GM/Opel factory with their belts and pulleys that go on new cars - I think if you stick with good brands Dayco, Gates, etc they should be ok. I have just bought a genuine kit to do a 1.7 Dti Corsa all sealed bags with the GM sticker and parts numbers on and the belt is branded Isuzu - who make this engine anyway. Pumps yes definitely keep with GM ones - unless we can find out who makes them.
    Carnoustie
    Thanks for that, have just found this one on Ebay and it's Gates?
    http://www.ebay.co.uk/itm/VECTRA-AST...item4aab85ed16
    would I be ok with this one?
    cheers Ronnie
    Middlesex
    Trim : SRI
    Mileage : 100k
    Just as a warning mate,I have known many non genuine water pumps leak. Genuine ones have a fitted metal gasket, and a lot of aftermarket ones are not as good.
    Just would hate for you to do it and then have to strip down again as you have a leak...
  1. Cdti 150 timing belt
    By John LE in forum Engine & Drivetrain
    Last Post: 4th January 2012, 12:30
  2. 150 cdti timing belt again
    By dubsrus in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2011, 09:33
  3. Timing belt on 1.9 cdti 150?
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2011, 10:35
  4. timing belt 1.9 cdti
    By fingers66 in forum Vectra C / Signum Car Chat
    Last Post: 1st October 2010, 18:49
  5. Timing Belt CDTi 120
    By ROB WOODHOUSE in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2006, 23:25
