Results 1 to 10 of 18
Thread: 1.9 cdti 150
    May 2008
    UK
    Default 1.9 cdti 150
    so after owning my vectra 1.9 cdti 150 for about 4 years, these are the problems i've had.....
    Replaced...
    Alternator, aux belt & tensioner
    Inlet manifold
    Egr
    Glow plugs
    Boost sensor
    Thermostat
    Cambelt, tensioner, idler, water pump
    Injector seal x 1
    Injector plugs x 4
    Blower resisitor pack thermo fuse & heater recirc servo
    Clutch/ Slave/ DMF/ & Crank oil seal
    Clutch pedal return spring
    Suspension springs x4
    Drop links
    Front arb bushes
    Rear hubs
    Rear upper control arms
    Rear hub carrier lower bushes
    Sump plug
    also...
    drivers side mirror fell off
    mould in bottom parts of tail lights
    headligts top part of plastic clouded over
    cruise control stalk intermittent - cleaned out contacts
    brake pipes under car gone rusty - wire brushed back and treated with rust killer
    all seem to be common problems .....
    Aug 2012
    Doncaster
    Nice,not even had mine 2 weeks and already feeling half that list,classic vauxhall self destruct quality.....should of listened to everyone and avoided it!
    May 2006
    scotland
    Jeremy Clarkson was indeed correct then????
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Hope you had a warranty....
    May 2008
    UK
    yeah apart from the injector seal, clutch/dmf, & manifold, i did all the rest myself, but no warrenty so not cheap..
    Aug 2010
    Leeds
    Look on the bright side the car has been overhauled so you can be happy.
    May 2008
    UK
    Quote Originally Posted by Bigtee View Post
    definately, is running sweet at the moment bud, wonder what will go next lol
    Aug 2010
    Leeds
    Is this a high mileage car as most of that lot will be expected like :Suspension springs x4
    Drop links
    Front arb bushes
    Rear hubs
    Sump plug
    Thermostat
    Sep 2010
    Am thinking this must be high mileage,... I've owned my last Vec CDTI 150 for just over 3 years and only replaced top shocker mount bearings - total cost £100
    Aug 2012
    Staffordshire
    Would a warranty cover most of these? Wouldn't they kick off and say these are general wear and tear? Hope not, mine is covered by warranty! *grabs documents*
  1. 1.9 Vectra CDTi 150 VS 2.0 CDTi 160 insignia Sri
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2011, 11:38
  2. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
  3. CDTi 120bhp Vs CDTi 150bp
    By bennyk in forum Diesel Engine related
    Last Post: 6th December 2006, 23:45
