Results 1 to 2 of 2
Thread: Window switches
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Default Window switches
    Just thought i'd preempt the problem i might be up against this evening. The problem is non-lighting door switches. Is there a fuse for them or could it be something more sinister?
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    If it is just the door switches that are not illuminating, then it is not the fuses.
    It is either a duff LED, or a loose / dirty switch connector.
    If you have no lights illuminating on the dash panel switches etc, then it could indeed be a fuse, or one of your modules has thrown a wobbler.
    quickest way to tell, is to open the driver's door, and all your panels switches should illuminate.
    or just turn on the light switch.
    If nothing illuminates, then check fuse 12 from the end of the dash.
    If this seems okay, then pull it out, and then put it back in - trust me, it often works.
    Common fix-it is to disconnect the main battery terminals for 15 minutes, and then reconnect them again.
  1. Window switches
    By VeccyMike in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2012, 00:42
  2. Window switches
    By coldo in forum Electrical & ICE (including SatNav)
    Last Post: 27th May 2012, 07:39
  3. window switches
    By elite lee in forum Electrical & ICE (including SatNav)
    Last Post: 11th June 2011, 11:38
  4. How do you disconnect the window switches.
    By garthmatthews in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2009, 15:01
  5. Electric window switches
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2007, 00:02
