Thread: Not starting..... Possible Starting Motor
    Regular Member portreathbeach's Avatar
    Jan 2012
    Cornwall
    Default Not starting..... Possible Starting Motor
    Just went out to my 2.0 dti Signum, turned the key and the car wouldn't turn over.
    When the key is turned, you can hear a clunk, which I presume is the solenoid engaging the starting motor, the display dims, but the starter doesn't spin.
    I read on another thread that the fault was the battery, but everything else is working fine and normally if the battery is low, the starting motor will still turn, but slowly.
    Any thoughts?
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Turn headlights on do they go dim?
    Whats batt voltage?
    Put car in gear try rocking it back an forward a couple of times. Put back in neutral an try starting agen
    Jan 2012
    Cornwall
    Just went out to the car to see if I could push it out the drive to bump-start it. Before that I thought I would try turning the key again, first time it clunked, the second time the starting motor turned over and it started fine??? I know my battery is a bit tired, but if it started, it can't be a faulty battery....can it?
    Could the starting motor be sticking?
    <edit> Critch, the headlights were bright, and all the car electrics are working fine. I did try the rocking thing earlier, but that didn't work. It's strange why it just worked for me a minute ago though!!!
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Possibly sticky starter. Or maybe high resistance in cable not allowing complete current flow.
    Woukd start with fresh batt/ charge batt
    Dec 2011
    Seaham
    Get your battery professionally load tested and tke the starter motor out and clean it.
    Jan 2012
    Cornwall
    I 'drop' tested the battery and it is fine. The car fired up first turn this evening after sitting there all day on the drive. The cables all look fine and connections are tight. I have a feeling the starter motor could be faulty as a few months ago I had the injector seals leaking, and I had to crank it over for 3 or 4 minutes to get the car to start. I did this for a couple of days until I got them fixed. I remember smelling a hot burning smell, which may have been the brushes or winding of the motor. Anyway, I managed to order a new motor today for £85 +vat from a local supplier, so I'll stick that in and see what happens
    Jan 2012
    Cornwall
    Changed the starting motor last night, what a pain to get too. Had to take off the turbo heat shield, starting motor heat shield, loosen the wiring loom to get to the starting motor rear support and removed from the top. Anyway, it turns over a lot quicker now and starts well. The old one smelt a bit burnt, so at least I know now I have a good few years in this new starter
  1. Z19 dt starting
    By mutley-k666 in forum Engine & Drivetrain
    Last Post: 5th January 2013, 19:03
  2. Car not starting!!!
    By bry607 in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2010, 18:14
  3. bad starting
    By jcbg21 in forum Engine & Drivetrain
    Last Post: 15th September 2009, 18:15
  4. EML flashing when starting but not starting (Vec-B)!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 29th July 2009, 15:51
  5. not starting
    By cavking99 in forum Engine & Drivetrain
    Last Post: 27th November 2006, 13:59
