Thread: Faulty warning light?
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    Default Faulty warning light?
    I have a warning message coming up telling me to check my rear right hand side brake bulb. So I have checked it and it is fine and working as it should. The fault keeps coming up everytime I getin the car though. Is this a faulty sensor of sonme description and is it possible to check the sensor or clear the message once and for all?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    well have you actually tried to change the bulb?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    The bulbs go high resistance as they get old and that's enough to trigger the bulb check. It usually means the bulb isn't far from going anyway, to be honest, I'd just change the bulb, probably find the error just goes away
    Engine : Z18XE
    I'll give it a bash and see, I've got some bulbs somewhere anyway. Will the error clear itself then?
    Engine : 2.2 Direct
    Yes it will
    Engine : Z18XE
    Cheers guys I'll let you know how I get on!
    11 Post(s)
    Are you sure it hasn't failed?
    The lower tail light takes over the role of tail/brake light should the upper tail/brake light fail.
    ie, when everything is ok - from top to bottom
    Indicator
    Tail light / brake light
    Tail light
    Fog tail light (drivers side only)
    Reversing light
    But when the brake light fails:-
    Indicator
    no light
    Reversing light
  1. Can faulty solenoid in EGR cause Spanner light 150 1.9 CDTi
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2012, 22:32
  2. faulty thermostat/limp mode/spanner light
    By collyb in forum Engine & Drivetrain
    Last Post: 19th April 2011, 20:20
  3. Bulb replcement light on but no faulty bulbs????
    By Blingbloh in forum Electrical & ICE (including SatNav)
    Last Post: 10th November 2008, 16:17
  4. faulty brake light
    By ANDY GSI in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2006, 12:45
  5. faulty Side Light Bulb
    By AJA in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2006, 00:11
