Results 1 to 10 of 11
Thread: Cruise Control not there?
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    confused Cruise Control not there?
    New to the site and now I have three fresh queries, two which may be linked...
    I fitted some second hand fogs and surrounds to 05 Vec CDTi, with front loom already in car, fitted new light switch plate blah blah blah...I now find that the cruise control no longer works...neither do the fogs coz they've not been tech'd yet..
    any clues peeps ?...
    The cruise could be your clutch spring, they are touchy, or you may have pulled a wire out when faffing around with the light switch ? My moneys on the clutch spring though ..
    Have to agree with Bainie.. it's sooo well known, i'd lay good money on your's failing..either change the spring or build up the lenght of the plunger so it's in contact with the pedal when the clutch isn't being pushed..
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    Default Cruise control ??
    Thanks chaps....however my better half just drove the veccy for 5 hours from Brighton to home....and guess what...it worked fine on the way back...yippee for now.
    You don`t drive with your foot on the clutch do you, I thought mine had stopped working then realised I was touching the clutch and it was enough to stop it engaging ? Maybe it was just having an off day like Vectra C`s like to do !!
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    Well the non working thingie happened to her indoors when she was driving down to Brighton on weds morning....obviously she blamed me for bogging about with her pride and joy....
    I was very diplomatic and asked her the same thing in an unpatronising way...
    She stated that she ensured that she kept away from both clutch and brake pedals when the failure occurred...
    Just a Vec C off day I presume...the other day the power steering warning symbol flagged up...I turned off the ignition..waited and turned it back on...all has been fine and dandy since..
    I love these vec c jobbies...
    Regular Member Matt21385's Avatar
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Stupid question but how do I go about changing the clutch spring as my cruise control dosent work?
    it's actually easier to lenghten the plunger on the switch.. if you want to do the spring, then you've got to disassemble the pedal box....
    i've successfully lenghten several plungers now with chemical metal.. just add enough to the button on the end of the clutch switch to let it work the switch when the pedal isn't pushed, normally about 4mm..
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    my cruise control stopped workin when my clutch pedal return spring snapped. i took it to vauxhall who told me the springs have been upgraded to a different type and replaced it under warrenty. now the cruise control works fine.
    ure clutch pedal spring mite ave lost a bit of its spring! and therefore a bit soft around the switch.
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Any chance you could do a how2 on this as I have no idea what your on about or know what the plungers are or where they are lol.
  1. Cruise Control.
    By adam_starkie in forum Engine & Drivetrain
    Last Post: 10th January 2011, 21:24
  2. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  3. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  4. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  5. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
