Thread: Vectra dti
    Jan 2010
    norfolk
    Default Vectra dti
    HI iv still got probs with fuel consumption , just wondered if i could get broken glowplug out without removing head and how and would this help towards fuel concern , need to get it done before winter thanks
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    glow plugs only aid starting in cold weather they do not effect fuel consumtion,as you say though you will need them working in winter with the Dti,engine will still start in cold with 3 working plugs but obviously 4 are better
    Jan 2010
    norfolk
    Default Vectra dti
    [QUOTE=jonnybravo;1876048]glow plugs only aid starting in cold weather they do not effect fuel consumtion,as you say though you will need them working in winter with the Dti,engine will still start in cold with 3 working plugs but obviously 4 are better[/Q
    hi thanks for reply , it smokes a bit on cold start up but clears when running
    Jul 2010
    Swansea
    Trim : LS
    Engine : 2.0DTI
    Year : 2002
    Mileage : 165000
    Quote Originally Posted by jonnybravo View Post
    Only starting with 3 plugs will use more diesel as its not heating properly, glow plugs do continue shortly after start up to keep the engine warm, without the plugs the engine uses more fuel on start up and uses more to warm the engine up. i made it through winter with only 2 working plugs but i thought i had a different problem and kept unplugging the thermostat sensor. As for removing them, im unsure sorry mate.
    Jan 2010
    norfolk
    thanks for replies will need to get done , would i need to change temp sensor to make fuel useage right
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Their are company's out their that can remove the damaged plug in situ
    Jan 2010
    norfolk
    thanks critch do you know of any in norfolk area thanks
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
