Thread: CD30 Replacement bulbs for display
    Wirral
    Default CD30 Replacement bulbs for display
    Hi. Does anyone know if you can get replacement bulbs for the Vectra C CD30 CD/radio display unit. All 3 have now blown. I once had a Citroen with a similar problem and couldn't get bulbs anywhere.
    Thanks.
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    I think you will find they are LED's (SMD) so will need new ones soldered on. Are you sure they are blown and not a fault/dry joint/cracked track on the PCB?
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Unless it's the TID (which it sounds like it is with the op saying that all 3 bulbs are duff) in which case i'd imagine they are replaceable. Not sure what fitment they are though.
    You should be able to pick up an entire replacement TID from a scrappers or the bay cheaply as there are loads of them kicking about and not in demand. Just swap the bulbs over if you're struggling
    http://www.ebay.co.uk/itm/VECTRA-C-T...ht_1197wt_1111
    Wirral
    It's the bulbs, not the whole unit. I've done 174k miles with the radio/cd permanently on and they've failed one at a time over the years. 3rd one went off today. I've had the unit out for a look and they twist out. Don't know if i could take some from a used unit because they're in a VERY brittle plastic holder which breaks when they're even gently twisted out. I had considered replacement of whole unit. Probably going to be the easier option. Checked ebay...quite a few about. I'll try the local breakers as well. Thanks guys.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    You could always go for the GID upgrade
    Wirral
    Sorry, what's a GID upgrade? Sounds good.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    It'll allow you to change your TID (triple info display) into a GID (General info Display)
    You'll end up with something that might look like this
    Wirral
    I'll see what the breakers have got. Thanks
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Be careful as if your car is full canbus (steering wheel scrollers) you'll need to get the new display divorced and re-married from the old HU and to your HU. There's also many different types of screen all of which have a 2 letter code on them. Someone on here might be able to advise which one you need.
    Wirral
    Managed to get new bulbs from main dealer. All fitted and in working bright shiny order!
    Thanks for the replies everyone!
  1. For Sale: CD30 and Display Screen
    By dti owner in forum Parts for sale
    Last Post: 16th February 2013, 19:29
  2. For Sale: CD30 & Display
    By Telly Addict in forum Parts for sale
    Last Post: 10th September 2011, 01:10
  3. CD30 and Display
    By Neil71 in forum Parts for sale
    Last Post: 19th November 2008, 08:40
vectra c stereo bulb replacement
vectra c bulb change cd player
can a vectra c run smd bulbs without a fault
change bulb stereo vectra c
