Thread: Egr valve stuck/ jammed
    Oct 2010
    bonnie scotland
    Default Egr valve stuck/ jammed
    Hi my egr valve jammed 2 weeks ago Causing engine to rev slow and have no power at all (wouldn't even rev past 3k)
    I stripped it and the spring bit that's goes in and out with the solenoid was very stiff cleaned it with brake cleaner, ran like a new 1 for 2 weeks
    Now same prob again. Can any1 shed some light on why it would happen again in so short time space?
    Regular Member borderlinechris's Avatar
    Jan 2012
    scotland/england border
    did you grease it up before putting it back together? i d mine following the how 2 on here but didnt make sure the pin bit that pushes was free enough , refitted and it did what you desribe, stripped it again and made sure it was really free and greased up before putting it all on again, no probs since! hth!!
    ireland
    im on the original egr,covered 110000 now,all i do is every six months take egr off and undo the little torx screws to reveal the plunger,then spray wd40 onto it, if u depress the plunger it sucks the wd40 into the unit,keep repeating till its nice and loose and a good amount of oil is drawn indie unit,ive never stripped it down completly
    West
    The EGR is evil & should be punished...
    blank it off & have done, in the long run the egr is killing your inlet manifold!
    Oct 2010
    bonnie scotland
    I stripped it today and put grease in it also, I had put ac90 on it 2 weeks ago hopefully the grease will do the job, running better at the mo, I have had a new inlet manifold not to long ago hope it doesn't kill that one lol
    West
    even the the newer manifolds die a slow painful death, thanks to the egr lol
  1. swirl valve stuck ??
    By coooky in forum Engine & Drivetrain
    Last Post: 27th June 2011, 19:46
  2. Jammed passenger seat
    By toghermi in forum Bodywork & Interior
    Last Post: 14th June 2009, 10:22
  3. Valve Caps Stuck on....
    By signum_1.9 in forum Suspension, Wheels & Brakes
    Last Post: 23rd February 2009, 10:45
  4. ccr2006 multichanger jammed
    By denny321 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd August 2008, 15:13
  5. Bloomin Valve Caps are Stuck !!!!
    By Bainie in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2006, 19:08
