Thread: 2.0DTI Y20DTH Crankshaft Sensor & Metal Shavings
    Jul 2010
    Swansea
    Trim : LS
    Engine : 2.0DTI
    Year : 2002
    Mileage : 165000
    Default 2.0DTI Y20DTH Crankshaft Sensor & Metal Shavings
    Hello,
    I have just finished cleaning my cranksaft sensor on the above engine and found loads of metal shavings all over the inside of it.
    Anyone have any ideas what they are from and what needs changing :/ im expecting the worse. My clutch makes a horrible noise when lifting up but not when fully pressed down.
    Thank you all.
    East Midlands
    Its very unlikely to be related to your clutch noise,i'd drop the oil and see if there is any swarf in the oil or on the sump plug as some are magnetic.
    Jul 2010
    Swansea
    Trim : LS
    Engine : 2.0DTI
    Year : 2002
    Mileage : 165000
    Quote Originally Posted by macdad View Post
    I have not long had a full service including new oil from a reputable garage is this problem common? I have read it could be the flywheel grinding down.
    Jul 2010
    Swansea
    Trim : LS
    Engine : 2.0DTI
    Year : 2002
    Mileage : 165000
    Is it possible for a damaged or worn clutch to cause this?
  1. Y20DTH Boost Sensor
    By colreid in forum Engine & Drivetrain
    Last Post: 22nd November 2012, 19:39
  2. 2.0dti y20dth throttle
    By chris70 in forum Engine & Drivetrain
    Last Post: 24th August 2011, 08:07
  3. Engine Problems 2.0DTi Y20DTH
    By Daniel89 in forum Engine & Drivetrain
    Last Post: 16th August 2011, 19:10
  4. 2.0Dti (Y20DTH) almost stalling - intermittent
    By MatB in forum Engine & Drivetrain
    Last Post: 7th June 2011, 17:45
  5. timing chain rattle then slip 2.0dti y20dth engine
    By bran.c in forum Engine & Drivetrain
    Last Post: 20th April 2011, 21:53
vectra c 2.0 dti crankshaft sensor
