Results 1 to 10 of 11
Thread: broken spring
    wellingborough
    Default broken spring
    hi all just got car back from full service and mechanic has told me front n/s spring has broken. showed me top of it broken off in his hand. also leaking shock on same side. undecided what to do whether to go for standard replacements or upgrade. ideas welcome?
    Dec 2011
    Seaham
    If you lower the car, you will have to fit a full set front and back.
    I would always recommend you fit both front ones and not just one new spring and shocker.
    wellingborough
    ive got a full set of lowering springs. so will i need just 2 standard front shocks
    Dec 2011
    Seaham
    Depending on how low your new springs are the shockers may bottom out? You may need some which are shorter.
    wellingborough
    springs are fk automotive with a 30mm drop bought from member off here
    wellingborough
    will they be ok?
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    the 30mm will be from a standard vectra you will be ok i have 30mm on mine with standard shocks no issues
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Go for bilstien B4,s equivelant to a standard vx shock only difference being they will last a whole lot longer
    and still loving it
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Find the cheap spring thread and have a read, as people had various experiences with the fk springs on various shocks.
    Regular Member v6vc's Avatar
    Jul 2009
    Planet Earth
    Vehicle : Vectra & Signum
    Trim : GSi & Design
    Engine : 3.2 V6 & 2.8 V6 T
    Year : 02/07
    I had the same dilema! I heard that a pair of standard springs from VX were £160 quid so I went for a full set of PI springs - £110! -30mm springs on standard shocks and I'm pretty happy with how it feels on these.
  1. Broken spring-what to do?
    By scotty84 in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2011, 20:10
  2. broken o/s/f spring
    By bat30 in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2009, 21:33
  3. broken spring!
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2008, 19:37
  4. Another broken spring...
    By shunter in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2008, 12:31
  5. broken spring
    By toshiba in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2008, 21:57
