Results 1 to 10 of 13
Thread: A number of problems with 1.9 CDTI 150......
    Nov 2009
    Argyll
    Unhappy A number of problems with 1.9 CDTI 150......
    A knocking noise coming from the engine which has gotten louder and louder (now sounds very rough) which has now resulted in the engine vibrating quite badly at idle and up to between 1000 - 1500 rpm. Also, I now have a lot of exhaust fumes entering the cabin. Not good!!
    Funny thing is though, there is no eml light or spanner light on, no loss of power or performance, no smoke (only a little on start up, but I'm assuming thats normal) and no overheating. MPG hasn't reduced. I've checked the oil and everything seems fine.
    Once you get going the car seems fine. Theres still the knocking noise but not as loud and the vibrating goes away. The fumes are giving me a headache right enough. I'm trying not to use the car because of the fumes but I have a long trip coming up and need to get it sorted. I live in the middle of Argyll, 3 hours from Glasgow so no dealer garage to hand, only a local garage but I was wanting to see if anyone has had the same problem before I go to him.
    FYI, I have a 2007 57 plate 1.9 CDTI (150) SRI, 80,000 on the clock.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    What smoke do you get on start-up, blue smoke?
    If so this could be related to the fumes as its likely to be an injector issue, can you whip the engine cover off and see if any of them are leaking?
    I had a bit of blue smoke with my CDTi on startup, but mine was EGR related, when blanked it no longer smokes.
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    When i had fumes in the car it was down to the flexi pipe on the exhaust which had a split in it, i think this is quite a common thing with vectras. Not sure about the vibrations, although a DMF on its way out would cause vibrations and a rattle, these rattles and vibrations are most noticable when the car is stationary.
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Does your car have a DPF? When mine is regerating you can sometimes get that smell in the cabin?
    Nov 2009
    Argyll
    Quote Originally Posted by rockafella8587 View Post
    Yeah its seems to be only when the car stops. I can coast at idle and it seems fine but as soon as I stop it comes back. Sorry to be a spanner but whats a DMF?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Fumes in the car normally point to the exhaust flexi being knackered
    Nov 2009
    newcastle
    Iv had the same fault twice. 1st was the flexi on the exhaust. 2nd time was the flexi neck on the egr cooler (on 120 engine) its down front of engine under the heat shield.
    Mine was more noisy one 2nd. (check your pollen filter if gas leak it will turn black with the exhaust gasesYou will only see the right hand section of flexi if heat shield fitted.
    If you want to see the part type in eBay egr cooler and cdti. eBay ones seem to have end pipes removed. Vauxhall only suppy full cooler and both end pipes. £110 plus vat.
    I only fitted right end pipe. If you need cooler and left bit let me know and sort a deal
    Caused by back pressure due to dpf mainly blocked. Fault will reoccur as goes at weakest point (flexi) will need dpf removing (like mine) or new (£1200)
    Nov 2009
    newcastle
    Dpf is an extra filter in the exhaust system that catches the soot then self cleans every so often. But these eventually get full and self clean. (estates have them but hatches don't ) these eventually can't clean anymore and block up causing back pressure. (can kill your turbo)My one sometimes would even force open a spring joint on exhaust pipe so couldn't find hole until it popped a flexi.
    Nov 2011
    Akrotiri, Cyprus
    Quote Originally Posted by mackemftm View Post
    Hi mate, a DMF is a Dual Mass Flywheel....it's a whole subject on its own lol. Type DMF failure into the search bar :0
    Nov 2009
    newcastle
    Sorry didn't read properly. I'd go with the dmf as others say (I didn't read properly-oops)
  1. cdti 150 pads part number
    Last Post: 1st November 2012, 14:46
  2. B12 Pro / B8+Eibach Part number confirmation for CDTI 150
    By muad_dib77 in forum Handling & Braking
    Last Post: 4th October 2012, 17:35
  3. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
  4. Part Number Air intake manifold 1.9 CDTI
    By cjamesenorf in forum General Chat
    Last Post: 17th September 2009, 07:57
vectra c 1.9 cdti 150 exhaust fumes coming into car www.vectra-c.com
vectra c cdti loss of power smoke and vibration
vectra c cdti has a new flexi pipe and now i get a vibration
vectra c 1.9cdti knocking noise on tickover exhaust flexi
