Results 1 to 3 of 3
Thread: Autobox Fluid Change - AF40
    Oct 2010
    London
    Default Autobox Fluid Change - AF40
    Morning guys,
    I'm going to be doing the annual service on my Vectra this weekend, and would like to know whether it would be worth doing the autobox fluid while I am at it?
    The car is at 45k and sometimes the gearbox can be a bit harsh on the up change. Is a slight crunch when going into reverse normal or something to be concerned about?
    Any advice would be welcome... I am aware these things can be expensive if they go wrong!
    On a side note, I do have the Haynes however is there any places which I should pay special attention to when I am inspecting the underside of the car? Anything specific to the Vec's which can be a bit of a problem spot? It's a 2008 Vec C 1.9CDTi 150.
    Thanks all
    Devon
    In relation to the ATF - yes abolutely 100% change it, and change it every 2 years if you only drain what is in the pan.
    If you don't there is a very high risk that the autobox will fail very early.
    Oct 2010
    London
    Thanks Dae
    I don't have the equipment or the confidence to do a full change so I will drop what I can and then add and then repeat again after a short drive to change a reasonable amount. Out of interest how much would a decent autobox specialist charge to do this, or a Volvo/Vauxhall etc garage? If it's not too much I would get it flushed through properly for my own peace of mind.
    Cheers!
  1. CDTI Autobox fluid
    By jay w in forum Engine & Drivetrain
    Last Post: 23rd October 2012, 21:36
  2. Is autobox af40 strong
    By s2yob in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2011, 17:30
  3. 19dti 6speed autobox fluid change
    By ramsgate in forum Engine & Drivetrain
    Last Post: 16th October 2010, 03:18
af40 fluid change
