Results 1 to 10 of 22
Thread: Field remedy info required
    Jun 2012
    scotland
    Vehicle : astra
    Trim : sxi
    Engine : 1.9
    Default Field remedy info required
    Im having the usual vectra cdti 8v (2008) cold start problems, work done so far
    new battery
    new glow plugs
    new leak off pipes
    fuel filter
    air filter
    erg and boost cleaned
    new coolant temp sensor
    iv found disconnecting the coolant temp sensor keeps the glow plug light on longer and starts the car first time, so im now looking for some info on a mentioned field remedy that keeps the glow plugs on longer, can anybody give me some info on this and how much it may cost? cheers in advance
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Starter motor?
    Seems to be the only thing you havent replaced yet!
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Deffo would replace starter
    Irmscher Insignia CDTI 130
    Jun 2012
    scotland
    Vehicle : astra
    Trim : sxi
    Engine : 1.9
    yeah iv heard the starter can solve these problems, but why is it stating after a long glow plug cycle? there is another member in the same situation he changed the starter and worked fine for few weeks, back to original problem
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    How about glow plug relay folks..... That ugly thing beside battery tray
    Nov 2009
    newcastle
    I'd do the relay next as this does the timing etc for the plugs. If you know some one with same motor swop them over to test in advance??
    Jun 2012
    scotland
    Vehicle : astra
    Trim : sxi
    Engine : 1.9
    i was on the understanding the ECU tell the realay how long to stay on for, unless im wrong?? does the relay have a timer ?
    36 Post(s)
    Engine : 1.9 DTH
    Quote Originally Posted by jaykay View Post
    Dont think it has however if is goosed then is not working properly can cause problem that u have
    36 Post(s)
    Engine : 1.9 DTH
    Also guys I don't really understand why u mention starter motor ???
    if he says he disconnect coolant sensor and starts first time surely starter motor got nothing to do with it , either is cranking or doesn't ..... I would be looking at glow plug relay , also are u 100% sure u have correct glow plugs in place ?
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by Sebastian View Post
    Starter motor - the reason it starts after disconnecting the coolant sensor is that if causes the glowplugs to run a much longer cycle than usual and when the engine is turned over if will fire up a lot easier - there are loads of posts re the starter motor being the cause of poor starting - as the motor gets older it will wear and as a result turns at a lower speed than is required to start the engine and will struggle - a new motor turns the engine over at a faster speed and solves the problem. I replaced mine after doing all the things the OP had done and have never looked back - it starts on the coldest mornings even without waiting for the g/plug cycle to finish.
    Have a look at http://www.vectra-c.com/forum/showth...tarting-issues and http://www.vectra-c.com/forum/showth...=starter+motor
  1. Field Remedy 1884
    By wotsthestory in forum Y & Z30DT Specific
    Last Post: 19th March 2012, 11:14
  2. Field remedy no for manual console creak needed!
    By stehanson in forum Insignia car chat
    Last Post: 8th November 2010, 16:06
  3. oil level , field remedy 1620
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2008, 16:37
  4. A little info required
    By phil67 in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2008, 11:27
  5. T I S info required
    By siadwel in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2007, 22:07
