Thread: More on SCV's Quick answer please!
    Apr 2012
    midlands
    Default More on SCV's Quick answer please!
    Right, my new SCV's have arrived but on the box it says Toyota avensis! They look like the right ones and they are a DENSO part but are they right?
    Where did you source them from?
    OE ones should come in a box marked GM with a hologram
    If they are used / reboxed then it is possible they could come in any box
    The parts should be marked Denso
    If these are indeed used, I do hope they have a warranty
    Plus it would be a large amount of time wasted if these do not work correctly when fitted
    The Toyota Avensis was never fitted with a 3.0 diesel engine
    Apr 2012
    midlands
    Nope they are new in a Toyota box, the Avensis is fitted with a denso fuel pump though...
    What is the part number on the box?
    Regular Member Johnny-B's Avatar
    May 2012
    Rīga
    Trim : Elegance
    Engine : Z30DT
    0960710-0052 un 096710-0062 I found those numbers from DENSO, valves came in lot of Toiota, MAZDA, NISSAN pumps, and all seems have similar problems with blocking!
    At yob I checked OE packing- outside was GM box, but inside was DENSO parts!
    Regular Member sir pingu's Avatar
    Jan 2012
    Klarup DK 40 cm away from Keyboard
    Vehicle : Vectra Estate Irmscher 3.0 CDTI
    Engine : Z30DT
    Year : 11 06
    Mileage : 301000 KM
    Quote Originally Posted by Johnny-B View Post
    096710-0052 un 096710-0062 I found those numbers from DENSO, valves came in lot of Toiota, MAZDA, NISSAN pumps, and all seems have similar problems with blocking!
    It's the right ones
    North Wales / Leeds / South France
    Maybe i am missing something but if all these valves were becoming 'blocked' surely that wpuld mean that the fuel filter is inadequate and any cost should be born by the manufacture of he vehicle, especially if you have a FMSH. Surely it is a case of the valves seizing due to lack of lubrication, i.e lower sulpher content (Diesel has had the sulphur content reduced dramatically over the last few years). i know from personal experience that using a fuel system cleaner and lubricator probably extended the time it took for them to seize in my y30dt, which was my fault because i didn't use Forte for the last 6 months before the seized.
    Apr 2012
    midlands
    Ok so the valves fit and car is happy again. Next time i think i will pay someone else to do it for me! But now I have a few leaky fuel lines! Not major but enough to smell in the car, anyone got any tips on tweaking them up?
    May 2012
    Rīga
    Trim : Elegance
    Engine : Z30DT
    Tommorow is time for mine SCVs :@ Today get them from local DENSO dealer, costs abowe 155 Pounds with discount! Hope that engine stopping staying at place will be gone!
  1. Old SCV's
    By JonnyB_UK in forum Y & Z30DT Specific
    Last Post: 17th August 2012, 19:19
  2. caliper carrier bolts quick answer needed
    By james walker in forum Suspension, Wheels & Brakes
    Last Post: 5th December 2011, 17:23
  3. Who can change scv's?
    By s2yob in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2011, 22:57
  4. Quick Question - Need a Quick Answer if Possible
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2011, 23:55
  5. V V Quick answer Req.
    By Baldy in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 11:57
