Thread: Sri V6 CDti - Tyres - 91W or 95W
    Regular Member ph67's Avatar
    Northamptonshire
    Default Sri V6 CDti - Tyres - 91W or 95W
    I need to replace all four tyres on the Vectra, it's the 3.0 V6 CDti Sri with the standard 215/50R17's - I'm settled on putting the same Michelin Primacy HP's on there but can save £120 as I can get the 95W's for about £30 each less than the 91W........I know the 95's are stronger and can take a bigger load but want to know if there's any reason NOT to fit the 95's?
    Has anyone got any reason why I shouldn't fit the 95's? do they produce more road noise than the 91's? or do they not last as long or have less grip?
    Your comments would be much appreciated. Thanks
    Your car would originally have been supplied with :
    215/50R17 95W XL
    You are supposed to continue to use this same specification
    The 3.0 V6 CDTI is right on the border line for XL rated tyres, hence why they were fitted to all body style
    On the Estate it just exceeds the limit
    You could therefore use 91W rated tyres
    However in the event there is one (or more) catastrophic tyre failures this pushes the remaining tyres over their load limit
    I have had one such failure and although I managed to keep control I appreciate continuing to use XL rated tyres
    There is no difference in road noise between 91W and 95W tyres, in the same profile specification
    The difference is the construction method
    Equally, there would be little difference between 225/45R17 and 215/50R17 (of the equivalent type)
    I am now on my third set of Michelin Primacy HP 225/45R17 94W
    Vastly cheaper than the 215/50R17 equivalent (when covering 35K miles a year)
    Finally, swap tyres rear to front as they wear
    This will mean running an old set of 215/50R17 tyres on the front for a short period, there is no issue with this
    Northamptonshire
    Thanks M8, much appreciated, when I bought the car it was 12 months old and came with Goodyear NCT's as 91W (they were a poor tyre!!) - good to know what it should have had on it. I'll be sticking to the Michelins but going for the 95W XL's as you recommend.
    11 Post(s)
    Quote Originally Posted by ph67 View Post
    Thank I'll be sticking to the Michelins.
    I can highly recommend Uniroyal Rainsport 2's.
    Very good grip, and last quite a while too.
  1. Replacement tyres 1.9 SRi CDTi
    By julian924s in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2010, 20:01
  2. Need 4 tyres for my 3.0 CDTi : Where to buy?
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2008, 19:11
  3. Tyres for 3.0V6 CDTi
    By James7 in forum Handling & Braking
    Last Post: 27th September 2007, 12:03
  4. XL tyres for 3.0 CDTi
    By wardy in forum Suspension, Wheels & Brakes
    Last Post: 7th September 2007, 20:42
91w tyre vs 95w
tyres 95w or 91w
difference between 91w and 95w tyres
difference between 91w and 95w xl tyres
