Thread: Replacing new front shocks. What else?
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Default Replacing new front shocks. What else?
    I am going to have the front shocks replaced soon with Bilstein B4s to match the ones I have just had put on the back.
    The front suspension has never been touched and the car has now done 133k. So what else is worth doing at the same time?
    I won't be doing them myself as I am not too handy with the spanners so don't want to add too much time to the labour!
    The car doesn't drive that well. At high speeds the front and rear doesn't seem connnected. The rear has hand new dampers and upper control arms fitted so I think my problem is probably the front.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Get me Strut top mounts an bearings.
    Drop links
    Wont add any extra labour as they needs to come off to change shocks anyway
    Also consider having the anti roll bar bushes changed.
    And I'm sure they will if it's going to garage but get them to check wishbone bushes for play
    Jun 2006
    North West
    Are the top strut mounts and bearings two separate parts or can you get a kit? How much are they?
    Just had a look at the drop links and the uprdated saab ones are about the same price so might go for those.
    Are the drop links the same as Anti Roll Bar Link Arms?
    Quote Originally Posted by Marky View Post
    yes the strut mount and bearing are 2 different parts
    the bearing is what the spring rotates on at the top of the suspension
    the top mount is a plate that has the bolt hole locations so that the whole strut can be bolted to the inner wing
    and yes drop links are the same as anti roll bar link arms
    Jun 2006
    North West
    Is it worth getting the VX top mounts and bearings or are aftermarket ones OK?
    I have had a quick look on ebay etc and nothing comes up for the SRI top mounts (13188764) they all seem to be the non-sri ones.
    They also seems to be quite pricey? It's looking like they'll be £120 for a full set?
    Thanks for the drop link info
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Can get a set of OEM (but they are actuall genuine ones with paint over part number) from Uni part for 57 quid a side.
    Quite expensive. But with that mileage you'll be surprised how much itll improve the feel.
  1. replacing front strut
    By rae287 in forum Suspension, Wheels & Brakes
    Last Post: 14th November 2012, 17:37
  2. When replacing shocks and springs....
    By Kev_A in forum Handling & Braking
    Last Post: 2nd June 2012, 17:28
  3. Replacing front subframe bushes
    By Cossy in forum Engine & Drivetrain
    Last Post: 6th April 2011, 23:42
  4. Replacing rear shocks
    By Marc 100 in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2008, 17:47
