Results 1 to 10 of 14
Thread: Cruise control help
    Regular Member Rudy's Avatar
    Jul 2012
    Hampshire
    Vehicle : Vectra sri
    Engine : 2.2 direct
    Year : 54
    Mileage : 48000
    Default Cruise control help
    Hi any help would be awsome here driving home ye other day using cc everything was fine I braked and now cc doesn't work vauxhall want £65 just to look at my car help please 54 plate vectra Sri 2.2 direct
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Brake switch has probably come loose
    Or the pedal return spring needs replacing for the modified one.
    Jul 2012
    Hampshire
    Engine : 2.2 direct
    Year : 54
    Mileage : 48000
    Any idea how i check those ??
    Jul 2012
    Hampshire
    Engine : 2.2 direct
    Year : 54
    Mileage : 48000
    Tried that still dosnt work
    Jul 2012
    Hampshire
    Engine : 2.2 direct
    Year : 54
    Mileage : 48000
    Right tired cleaning the stalk nothing tried pulling up the breake pedal and clutch pedal still nothing have been reason the forums for over an our now and everything I see is saying about a clutch switch however my question now is can that be my issue as I didn't use the clutch I simply breaks and then went to engage the cc again and nothing please help I'm lazy and need my cc lol thanks
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Just wondering - have you done the soft reset of the modules?
    That is - disconnect the battery for about 15 minutes.
    Do not do this within 5 minutes of running the engine, as the whole car needs to shut down properly (just like a computer does).
    Then after this 15 minute period, re-connect the battery, and see if the fault has cleared itself.
    For cruise control to stop working like this, I would assume you may have a faulty brake switch..
    Have you cheked to see if your brake lights stay on all the time whilst the ignition is on - this would point to a shorted /faulty internal switch contact.
    Other than this, check that the wiring from the brake pedal switch is not shorting to earth or something - this has the same electronic effect as pressing the brake pedal
    Jul 2012
    Hampshire
    Engine : 2.2 direct
    Year : 54
    Mileage : 48000
    Thanks for all your help now listen to this after spending 6 hhours looking at the forums taking the car apart and putting back together several times I gave up for today gose out to the car finds my dash back light won't come on take it apart again sort that out and the ****** cc is now working WTF lol if any one has any ideas why this has happed please explain lol thanks
    Engine : 1.9 CDTi
    Where are based as someone local may be able to read any stored codes to point you in the right direction.
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
