Thread: battery or alternator?
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    Default battery or alternator?
    went to start the car today 1.9cdti 16v and it just clicked
    jump started it and it was fine but lights were dim inside and the p/s light came on
    battery light isnt on though?
    its only getting about 9v on the terminals when running
    how do i figure out if its the battery or the alternator?
    Regular Member Das's Avatar
    Turdsville
    36 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    If the battery is goosed you should still get 14.4v at the terminals with the engine running. Looks like the alternator at fault. If your a member of the AA etc they should be able to test your battery when they come out too.
    Jul 2012
    Scottish borders
    sounds like the alternator then, just called my local parts and they said they have different amperage alternators?
    90-105-125
    will it matter what one? mines is a denso one
    Turdsville
    36 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Not sure about that, but id have thought you should be able to put on the higher amperage one.
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    What's battery voltage before engine running?
    I suggest charging or changing battery before fitting new alternator.
    As it could shorten the life of new alt trying to charge a dead batt
    Jul 2012
    Scottish borders
    alternator is off and its being collected tomorrow with another being dropped off
    Jul 2012
    Scottish borders
    New alternator fitted and running fine
    Turdsville
    36 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Did you put the higher amperage one on?
  1. Alternator or Battery
    By Jamie in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2011, 21:30
  2. Help With Battery/Alternator
    By Ultim8 in forum Electrical & ICE (including SatNav)
    Last Post: 27th May 2011, 14:37
  3. Battery, alternator or something else?
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2010, 16:19
  4. Alternator or battery?
    By RobW in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2010, 22:20
  5. Alternator or Battery?
    By callist in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2010, 20:24
