Thread: Engine Help please, Vectra C 1.8 LX
    Canvey Island
    Default Engine Help please, Vectra C 1.8 LX
    Good Morning Again,
    I had my cambelt and a full service done last week. Once i got the car back it was running lumpy and jerky when pulling off at low revs.
    The car was taken back last week and the cambelt was taken off to ensure it was alligned properly which it was, but still running lumpy.
    It went on the diagnostics machine and came up with a cambelt sensor fault, and this was replaced.
    However the above has not made any difference to the running of thecar , still lumpy and jerky at low revs, its as if it doesnt have enough air coming into the engine, and the
    exhault quietly pops id assume dur to no air.
    The mechanic has said that he has had effects the other way when a car has been over revving but not under.
    Does anyone have any ideas or previous expereiences with anything like this?
    Could it be a cracked spark plug, or plug lead? ive heard also a lambda sensor mentioned
    Anyone got any ideas or tips on what the next steps would be?
    The guys taking the car back to replace everything that was put in for the service to ensure theres not a faulty part that was put in.
    Neil
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Is it only when pulling off? Or is it lumpy at idle an other gears?
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    still sounds like timing , once had a zafira 1.6 brought into me with similar running problems after a timing belt replacement & the inlet cam was a tooth advanced , exhaust was a tooth retarded .
    with the mark on the crank pulley lined up to the mark on the back casing you should be able to draw an imaginary line across the 2 cam pulleys , straight through the centre of the bolts & both timing marks .
    Canvey Island
    Its jerky when pulling off and lumphy when Ideling, nightmare when im at lights as its looks like i cant drive! But when coasting it doesnt seem to do it, but could be doen to the fact i cant notice as its in motion.
    Still seems to be ideling at the same revs its always done 600 - 900
  1. Vectra c engine ecu
    By accors in forum Engine & Drivetrain
    Last Post: 21st August 2012, 21:53
  2. Engine Oil For Vectra VXR.......
    By Jayson VXR in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2012, 18:22
  3. Engine Oil for VXR Vectra
    By STEVE S in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2011, 23:14
  4. Vectra C check engine HELP!
    By claudiu666 in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 22:02
