Thread: 2008 Vectra rear knocking
    Aug 2012
    preston
    Default 2008 Vectra rear knocking
    Hi everyone,
    1st time here.
    I have a 1.9cdti vectra and it has a really annoying noise from what I think is the N/S rear.
    It's been checked over by two garages & myself, I fitted a pair of new shockers as well to the rear.
    It's like a hollow knocking noise, not necessarily just when going over bumps but also just on slightly uneven roads.
    I cant see any play in any bushes and everything "looks" Ok .
    Please has anyone any ideas ?.
    Thanks in advance.
    South east
    This will give you a long list of things to check:
    http://www.vectra-c.com/forum/showth...-Needed-Please
    merseyside
    I had the same thing,sounded like it was the Parcel shelf or something in the boot,i had already had the Shockers changed,they were well worn.I no you said its been looked over for bushes,but mine turned out to be the Rear Anti-Roll Bar Bushes,which had worn in the center were the Anto-Roll bar goes through,they hadnt cracked or split or nothing,fine after changeing them. About £9 from the stealers.
    Nov 2009
    newcastle
    Same here. Was rear bushes on my estate.
    Cheap and easy fix to rule it out
  1. Vectra C, 2002, Rear Suspension knocking/creeking noise
    By richardkay007 in forum Suspension, Wheels & Brakes
    Last Post: 11th May 2012, 19:05
  2. No rear centre head rest in 2008 150 CDTI Vectra
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2011, 18:08
  3. Vectra C 2008 Left rear view dimming socket problem
    By nyilkin in forum Electrical & ICE (including SatNav)
    Last Post: 8th January 2011, 16:26
  4. vectra 1.8 duelfuel 2003 knocking at rear
    By sparks in forum Suspension, Wheels & Brakes
    Last Post: 19th February 2010, 00:39
  5. vectra c rear wheel knocking
    Last Post: 24th January 2010, 21:05
